Dvd solely stays in loading mode and does not go into play mode
There are a few different things that you can try. First make sure that
your discs are clean before you put them in the player. Even if the
disc is new I would recommend cleaning the disc off. The second thing
that you can try is a DVD player reset. You can do this by unplugging
the player for about 5-10 minutes. Then plug it back in and try the
disc. If that does not help I would try a DVD head cleaner in the
player. If all of these things do not work, it is most likely an issue
with the player.
the laser inside may be having the problem or the optical sensor inside the player is not proper.....
if after all the above said procedures fail kindly contact ur manufacturer.
thank you
I have the same problem and I have already tried all of the suggestions listed. My player is just 6 months old. Any othr suggestions?
