Question about Kenwood CT 401 Hi-Fi Stereo Dual Cassette Deck Single Dual Cassette Deck
Given with no instructions.can i copy from a cassette to a cdif so,? it's a kenwood rx-28
1 Related Answer
Anonymous
  • 319 Answers
SOURCE: kenwood cassette receiver rx-28
There are sensor leaf switches that may not be contacting properly or the drive belt may be too slack to position meachanism properly. Have it checked by pro/tech
Posted on Apr 25, 2008
Kenwood rx 28
Try contacting Kenwood through - http://www.kenwood.com/
and see if they can tell you. Sorry I have no idea.
May 06, 2014 | Audio Players & Recorders
I have a kenwood Rx-28 Sterio cassette Radio when you switch on the Power Switch error "Protected" comes on
It is not so easy to probe into to find a protection fault condition. The fault can be your output drivers- the mosfets fitted for both the channels,or a short in any of the primary circuits. Use a meter after disconnecting to check for short in the drivers. Disconnect the positive and negative voltages to the output and see if the protect changes.
Elimination of the circuits will determine the fault. If so replace the outputs. If not there can be issues in the mother board, maybe the protect circuit by itself is shutting off due to a faulty bias , maybe a leak in any voltage/current sensing circuit.Also disconnect the speakers and test, if the protect is off then check for short on the speakers.
May 02, 2011 | Audio Players & Recorders
Manual+ recipe book for FP580 food processer
OR Alternatively copy and paste this link:
http://safemanuals.com/user-guide-instructions-owner-manual/KENWOOD/FP486--2405%20FP480%20%2526FP580%20ENG
And hit on the adobe pdf link...
Mar 25, 2009 | Kenwood Food Processors
Kenwood tuner/graphic equalizer c-h6
sound output section trouble.can you remoove and shall we start rectifing the problem.
nuwan
Dec 04, 2008 | Kenwood CT 401 Hi-Fi Stereo Dual Cassette...
Kenwood cassette receiver rx-28
Apr 13, 2008 | Kenwood CT 401 Hi-Fi Stereo Dual Cassette...
Kenwood KA-72B Stereo Receiver HELP NEEDED.
Why not plug the cassette directly into the CD recorder? Are they trying to achieve some eqalization change? If not, then this should work. It's all analog at tape level.
Mar 02, 2008 | Audio Players & Recorders
Top Kenwood Audio Players & Recorders Experts
Michael Thomas
Michael Thomas
Kardoc
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
