1) No start after disconnecting battery could be the Security system going into tamper mode. Perform the reset procedure. key to start, wait, etc. There are videos. This might fix it all. If you still have trouble with the key being stuck (another flag for the tamper lockout theory.) replace the lock cylinder and key. Remember to reset procedure.
2) trans shifter has a lockout solenoid that is controlled by a switch at the brake pedal. Could be tamper lockout. Taken with the brake lights and windows and locks I would then look for a common 12V source, ie fuse, relay, fusible link. Fix one might fix them all. The brake lights and the shifter lockout for example converge at the brake pedal switches. Not likely the brake bulbs coincidentally burned out, but possible. The Electronic troubleshooting manual used to be called EVTM Electric and Vacuum Troubleshooting Manual for your model is the best resource for finding wiring diagrams and locations of fuses, relays, connectors.
Power off your computer and then remove the monitor cable from the port on the back side of the computer case. Reattach the cable and make sure the pins are correctly screwed in. Power the computer back on and check to see if the OSD lockout message is still being displayed. Check the manual that came with your computer or monitor and locate the troubleshooting section if you are still receiving the OSD lockout message. Find the OSD lockout heading and read the method that your particular model uses to remove the lockout.
Attempt generic lockout removal procedures if you no longer have the manual that came with your monitor.
Press and hold the "Menu" button located at the bottom of your monitor for 15 seconds and wait to see if the OSD lockout message disappears.
Press the "Menu" button again if the lockout message remains on the screen. Use the arrow buttons to navigate through the main menu options. Highlight the "Settings" or "OSD Menu" option and then hit the Menu key again to access the new list of settings.
Scroll down to the "OSD Lock" heading. Use the arrow keys to change the setting to "No." Hit the Menu key again to return to the main menu. Scroll to the "Exit" setting and then hit the Menu key a final time to exit the menu setting and remove the OSD lockout. hope this helps
