SOURCE: Gateway laptop vertical dotted lines across the screen
Sounds like a problem with the LCD assembly or cable. You may want to reseat the LCD cable at the LCD end. It could be a loose internal connector in the LCD assembly.
Ron-
SOURCE: Strange Green Vertical Line
I encountered a problem with my sony vaio laptop after installing windows xp. It lost sound and keeps reporting that it does not have sound device when i try to play music.
SOURCE: black screen with horizontal green lines
Hello yoyoxide.
from my experience can be something related with the video card. I recommend you the followig (Hardware diagnostics):
-Look for one of the discs that came with your computer, it should say (Drivers & utilities).
-Boot from the CD. If you don't know how to do it do the following:
1.Insert the Drivers&Utilities Disk.
2.Restart teh computer.
3. When you get the Dell logo, press F12
4.Select Boot from CD/CDRW-DVD (something like that).
-You will get a prompt to run the diagnosics.
-Just follow the wizard
-I recommend you to run diagnostics for everything.
-You will see if you have any problems with your hardware.
It seems that you have a pretty new laptop, so probably it's under warranty.
SOURCE: Lenovo 3000 N100 Screen Problem
First, plug a external monitor and toggle the screen to discard configuration or software problems. If the image displays correctly you have a problem either in the LCD screen or its connection cable.
Open the bezel and check for loose or damaged connection cable. Look specially next to the hinge, ON THE LEFT.
In case the problem is not the cable you might have to get a new LCD. You can have replacement parts and instructions here:
http://www.piezas.biz/epages/wwwpiezasbiz.sf/en_GB/?ViewObjectID=56222
SOURCE: vertical line on screen Lenovo T61 Laptop
You have a dead column of pixels. The only solution I'm afraid is to replace the LCD screen.
I'm sorry the news isn't good but can you take a moment and rate the solution as fixya even if it wasn't what you wanted to hear? Thanks! :c)
