Question about Safe International Digital Electronic Safe Lockbox Gun Jewelry Lock Box Tool
I have replaced the battery's in the safe and the code i set has been enabled, how do I reset a new code to open the safe? I have a Kingavon electronic safe 28.
Thank you fr youe help
Verity
I have on old safetron aanon elctro mechanical safe and i don't forgot the code can somone tell me how to reset it
Posted on Jun 28, 2011
Can You tell me how to set the electric password
Posted on Dec 26, 2014
SOURCE: I have lost my pin and backup keys + battery dead!
whats the default code for gordon digital safe box sk#p45981
Posted on Jun 01, 2009
Feb 16, 2015 | Locks & Locksmithing
Enter your code on the keypad located on the front of the safe. Some electronic digital safes require you to input a special character like "#" before and after your code. The safe should either beep, have a LED turn green, or display "OPEN" if you have correctly entered the code.
Turn the handle to the right within five seconds of correctly entering the code. If you wait too long, the safe will lock and you will have to enter your code ag
Open the safe with a key. Use your emergency key that came with the safe to open it if you forgot the code or if the batteries have died. Remove the key cover from either the handle or the control panel to reveal the lock.
Enter your code to open the safe.
Place the electronic digital safe into code reset mode. On some models you need to hold the last digit of the code or press the "*" button to get into code reset mode. Other safes require you to open them and press a small red button on the inside of the door.
Enter your new code on the keypad and press "#" to finish. Some safes may require you to press "*" or a letter to finish the code. If the safe requires it, enter the new code again to confirm that you entered it correctly.
Use your code to open the electronic digital safe's door.
Locate and remove the battery cover on the inside of the door.
Replace the used batteries with new ones. For most safes, this will require two or four AA batteries.
Test the batteries. Use your code while the door is open to test the batteries before closing the safe.
Feb 08, 2015 | Locks & Locksmithing
May 21, 2014 | Safe International Digital Electronic Safe...
Nov 01, 2009 | Home Security
Oct 04, 2009 | Safe International Digital Electronic Safe...
Jul 22, 2009 | Kitchen Appliances - Others
May 28, 2009 | Safe International Digital Electronic Safe...
May 12, 2008 | Dryers
17,681 people viewed this question
need to change code on kingavon electronic safe 28 as existing code keys worn out.
how do i set anew code
i want to change the code of my safe. Hou can i do that. to confirm the new code I need to use the lettre B but there are no letters op the electronic pad.
I have a kluis felix se-2 safe I have changed the batteries but the code still will not work?
my sentry safe has an electronic combination, but when i put in the combination, it says proceed but it does not open. I changed the battery twice already
Safe locked and battery is almost flat. Only orange light flashing not green to open
While entering the code, safe did not open. I managed to open it with factory code, but now I need to insert the new code. please advise
I don't now factory code
