Question about Citizen Eco-Drive BL006056H Wrist Watch
My problem is my Citzen Eco Drive works but the WR100 seems to be off. I under the theory of WR as opposed to water proof but, should it really be getting foggy under the crystal after i wash my hand? On a smaller note, how do i set the calender so it actually changes correctly with the day? Thank you in advance.
Posted by acoustic_blu on
Anonymous
  • 23 Answers
These water proof watches are only water proof if the knob for setting the time is pushed all the way in. Try to call your Citizen dealer, if you read them the numbers on the back yhey can see if there is warranty to check the problem for free.
If you need to know more about your Eco Drive, look for detail tech manuals for all types here: http://www.citizenwatch.com/downloads/tech/tech.htm
Posted on Jun 25, 2009
Where can I buy an authentic (Ladies) Eco Drive WR100 Watch battery, in NSW please?
You can not, you need to send it into Citizen Watch Co. do not touch the rechargeable battery it should only be handled at the factory you will also void any future warranty with Citizen if you try to change it.
Aug 29, 2011 | Citizen Eco-Drive BL006056H Wrist Watch
Will/could you advise me on how to reset the time on my Citizen Eco drive wr100 watch that I purchased last year. Can't find my manual. Thank yo so much.... Happy Holidays!!!
1. Pull the crown out to position 2, two clicks.
2. Press and release the lower right button.
3. Rotate the crown to adjust the minute.
4. Press and release the lower right button.
5. Rotate the crown to adjust the hour.
6. Press and release the lower right button.
7. Rotate the crown to adjust the date.
8. Press and release the lower right button.
9. Rotate the crown to adjust the current month and leap year.
10. Push the crown to position 0.
Dec 23, 2010 | Citizen Eco-Drive 180 WR100 World Timer...
I have a men's Citizen Eco-Drive WR 200. Why does my digital time accuracy differ by 2 mins from the analog setting? Thank you, Wayne
The analogue time can be set to agree with the digital time by following their instruction manual.
If you go to http://www.citizenwatch.com/COA/English/settings.asp and follow the instructions, you can download the ones for your watch.
Sep 28, 2010 | Citizen Eco Drive Chronograph Perpetual...
Oil all over wrist watch - can it be cleaned?
hi, if the watch is water proof witch most watches are, if it is it should tell you something on the back like wr 30m or wr 10m if it says this on the back then this is telling you that the watch is water proof up to 10metres or what ever it says if this is the case then you can put it in the sink with only slightly warm soapy water then just rub it over gently with soft cloth whilst under water.
How ever if it says water resistent then this dont mean its water proof this just means its rain proof but not made for going under water unless it says water resistent to 30m then this can be washed in the sink also if it dont say this then you cant put it in the sink you can only wipe over it with a damp cloth to remove as much oil as possible.
But if you can get it clean and its not water proof then the watch is going to have to be taken apart to clean the outer casing that is only if the oil has not got inside the watch.
Oil wont short the watch out put it can cause problems if you have any buttons on the watch so your best bet would be taking it into a watch shop and get it cleaned that way.
Let me know how you get on or if you need further assistance ok
Jan 27, 2010 | Watches
Citizen Eco-Drive
Could be that the watch inside and outside numbers do not match. If the dial says Eco Drive, that should be the first step. Next, find out about the 4 digit number that tells you which type we are looking at. You may want to open the back and look at the number on the watch internals. But be aware you may damage the water proof seal in doing so.
Really, you should write down all numbers you can see and send an email to citizen. They will help you.
If you need to know more about the Eco Drive, look for detail tech manuals for all types here: http://www.citizenwatch.com/downloads/tech/tech.htm
Those are great watches as long as you remember it needs light to charge.
Jun 09, 2009 | Citizen Eco-Drive BL006056H Wrist Watch
Citzen eco drive watch stopped when i changed time
Try to find solution here:
Interactive settings are very helpfull as well.
Rate, please.
Mar 30, 2009 | Citizen Watches
Setting my citizen watch
i need to set the time on my citzen eco drive modle number 550198. the hands will move but once have set the time it will not run.
Jan 19, 2009 | Watches
Citizen eco-drive problem.
Hi Try www.citizenwatch.com for your manual of instructions.
Try Leaving watch in direct strong sunlight or under bright light for at least 12 hours.
Aug 23, 2008 | Citizen 8700 BL8000-54L Wrist Watch
Citizen Eco-Drive BL006056H Wrist Watch Logo
376 people viewed this question
Top Citizen Watches Experts
Janelle Schoonover
Janelle Schoonover
Lisa Christine
Bruce Robin
Are you a Citizen Watch Expert? Answer questions, earn points and help others
