SOURCE: memory card will not stay down in a nikon coolpix s210
Hi, I have exactly the same problem. However, instead of getting a new body with a broken screen and exchanging my screen (One of the only ways round it) I thought I'd try something.
I folded a piece of paper (Quite a small piece) and put in on top of the card when it is popped. I then just closed the battery/card cover and it stayed in place. This is a cheap way of fixing it, it's now been fine for a while, it's a bit of a shoddy fix but it's better than paying nikon £50 to get it fixed.
It takes a couple of trys, getting the paper the right size was a little bit of a pain but it now works fine.
Good luck,
J
SOURCE: Memory card works in PC but not in my Nikon camera.
You have to change it from the menu from "Save images to camera" to "Save images to Memory card"
SOURCE: camera wont turn on, bent pin in card slot
ouch!
send it to the service centre ...
trying to fix the problem yourself may just inflict more damage ...
SOURCE: Camera won't accept an SD Memory Card anymore
Hello
If the card works in another camera or another card doesn't work in your camera , the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
SOURCE: My E8800 sometimes shuts off when I click the shutter
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the
probability is that you will have to get it fixed by a professional.
Use
these at own risk as it may further damage the camera.
Firstly ,
try connecting your ac adapter or usb cable.
Try holding the
shutter button while switching on the camera.
Look at the lens ,
and if some of the lens 'circles' is misaligned or not concentric then
try wiggling it (while holding camera lens down).
Try gently
pushing or pulling the lens when it extends but this is risky as it may
cause the lens barrel to slip out of its guidance system.
Another
way to do this is to place the camera lens down on a hard surface and
then power it up. Be sure to use a soft cloth or something similar as to
not scratch your lens or casing. Let the lens push the camera up and
down a few times and sometimes the little resistance provided by the
camera is enough to get things going again.
Try hitting your
camera near the lens on the body with the soft tissue on the palm of
your hand.
Other than that , I would take the camera to a repair
center for a evaluation to see if it would cost more to repair than to
replace the camera.
If it is still under warranty I would suggest
you take it in before trying any of these steps and remove any
off-brand batteries or accessories as some stores are really fussy about
warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope
the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
