Question about Dell PowerEdge 1600SC Server
We have an old Dell PowerEdge SC430 that beeps continuously, however it's functioning normally. We replaced the motherboard battery, as that was the first guess, that didn't work. It's has no RAID setup.
Posted by Barend on
Kaushik Patel
  • 67 Answers
It seems to be DRAM refresh error. Kindly unplug the RAM and plug it back.
Regards,
Kaushik Patel
Posted on Nov 07, 2013
4 Related Answers
Anonymous
  • 61 Answers
SOURCE: Dell Poweredge 700 Server problems
Dear jckim, Which server you are using? Usually this error occurs when raid controller card have some problem.Have you getting any error codes?
Posted on Oct 23, 2008
Anonymous
SOURCE: Dell PowerEdge 1400 Server Problem
Failed memory.
Posted on Nov 14, 2008
Shawn DuRee
  • 356 Answers
SOURCE: No power on my PowerEdge 1800 Server
dells power supplies must come from dell. I would call dell and give then the service tag number of your server and they will be able to tell you about how much a power supply is.
Posted on Jun 07, 2010
ded_ch
ded_ch
  • 12 Answers
SOURCE: Dell poweredge t110 Raid 5
In a RAID 5 config, you need at least 3 drives (you can have more however). A small part of every drive is then reserved for recovery data for the other drives. So two drives together hold all the data needed to restore a 3rd drive.
The Raid Controllers in the Dell Poweredge Servers are hot swappable. So you can just pull the faulty disk and then insert a new replacement drive in the same slot (Needs to be the same type and size or bigger. However, if the disk is bigger than the other 2, then only the size of the two other disks will be used on the new drive). The Raid controller will then see that there is a new disk and automatically start the recovery process. You will be able to see this when you open the Controller software. Once the recovery is done, the RAID 5 will be fully functional again.
While one of the disks is faulty or missing the two remaining disks will continue to work, but at the severely degraded performance. After the rebuild the performance will be back to the way it was before.
The rebuild can take more than an hour, depending on the disk sizes used.
There is also an option on some Controllers to select one drive as a "spare". Then you insert one more disk and set it as spare. It will not start working unless one of the other disks in the Raid fails. That's when it is used automatically as a replacement.
Posted on May 02, 2011
I am having a problem with my dell poweredge 1800, it beeping continuous
Assuming this is still an issue...old as it is...
You need to boot the server and press the correct prompt to enter the BIOS of your PERC RAID controller. There you need to manage your physical/logical volumes.
Chances are that either you had a drive failure or the metadata on your RAID volume (JBOD?) was corrupted. This is a common issue with these LSI-based PERC[5-6]i RAID controllers that Dell utilized.
Jan 18, 2014 | Dell PowerEdge 1800 Server
Hi. I Inherited a DELL Poweredge 1600SC server. When I switch it on, it powers up but the screen remains blank [black without any beeps]?? I remove all the memory and switched it back on again = NO beeps....
I guess you can't go into start button. /anyway how did you know if computing is powered? On your keyboard top line keys have screen control keys for brightness etc.eg f4. try.
Aug 01, 2013 | Dell PowerEdge 1600SC Server
What could be the problem when you power on Dell Sc 430 Poweredge, you get only a blinking orange color?
these servers are single power supply when that goes you only get a blinking orange light and no beeps.
most other issues will beep code.
I would start there. you can remove and reinstall. but it is probably bad
GL
hope this helps
Don't forget to rate my answers
Thank You
Jammer
Sep 23, 2011 | Dell PowerEdge SC430: SC430 Server 2.8GHz...
I can not see display while i start my dell poweredge sc430.
check your cable PC to monitor or try to added vga graphics card
Jul 22, 2011 | Dell PowerEdge SC430: SC430 Server 2.8GHz...
PowerEdge 2850 server beeps as soon as it is turned on - 3-2-1 beeps format. What has failed?
the beeps are post during post the very first work is done by the ram,all the memory in the ram is first transferred to the hard disk,and remains active untill turned off.
make sure that your RAM is securely seated
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them they could be faulty
a computer needs its connections to continue its cycle and to have and end to function
obvisously the beeps are windows searching for some hardware it could be RAM cd/dvd hard drive or motherboard all of these must have secure connections for the computer to work
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure make sure the connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error
hope this helps
May 03, 2011 | Dell 3.0 GHz Second Processor for...
Dell Sc430 Poweredge gives out Hot Air...Nothing to do with the performance all stable .but it gets difficult to sit around it and work..
What can I suggest?
Maybe there is a problem with the processor working too hard as there are too many files to get through?
Maybe a virus is in there making the hard ware work too hard?
Have you noticed the hard drive light working more than normal? if so this could be a reason as the processor will have to work harder, causing more heat, when it is busy trying to cope with an extra problem.
Oct 16, 2010 | Dell PowerEdge SC430: SC430 Server 2.8GHz...
Poweredge 600-SC RC 4Hr J3717 ASSY, Tray, (5Y002) Motherboard: what does it mean when an dell poweredge 600 sc pr...
Three sets of beeps, or three individual beeps? Does it repeat? If so, then check this for the code you are hearing:
http://support.dell.com/support/edocs/systems/pe600sc/en/it/1r237c20.htm#1046231
If it is a steady once-per-second beep - or a constant screech - and it is able to boot to the OS (or even most the way), then it is probably your RAID controller. Boot to CTRL-A or CTRL-M to check the status of your array.
May 16, 2010 | Dell Poweredge 600-SC RC 4Hr J3717 ASSY,...
Beeping Upon Bootup
dependent on how many beeps you hear is dependent on what might be the problem. A fuller explanation from pushing the power button to nothing happening would be more than helpful. Beeps in a Poweredge can mean motherboard, memory or as you said power supply problems.
May 06, 2008 | Dell POWEREDGE 2400 Server
Dell PowerEdge 1600SC Server Logo
211 people viewed this question
Lee Hodgson
Lee Hodgson
efs_perpends
efs_perpends
Michael Thomas
Michael Thomas
