Jensen VM9410 Car DVD Player Logo
Question about Jensen VM9410 Car DVD Player
Jensen player I need the code for jensen vm9311ts dvd player. Can any one help ...thanks
Posted by eazzi2u on
Anonymous
Insert the DVD
After the disc loads and plays you will see a blue screen telling you "it is unlawful to drive with a movie blah blah blah"
1)Activate the brake sequence and disable the blue screen using the hand brake, the switch method or anything else to give the unit its three pulses to disable that freakin blue screen.
(What I did was I installed my radio entirely, then took the pink wire and touched for two seconds, removed for two seconds and then touched and held the negative pole of a mower battery laying on my passenger seat until the screen was no longer blue.)
2) Next, on the main remote press stop twice, then 1, 2, 6, 4.
You will now see a hidden menu that says:
Region Code
Brake Override (I know you're drooling by now)
Macrovision (Watch all the burned and pirated movies you want if this option is off)
Loader Version
Model Version
3) Using the right joystick on the unit, navigate to the options of your choice, click on them to toggle on, off or which region code you want.
This is what you want:
Region Code: 1
Brake Override ON
Macrovision: OFF
When your done, click SYS SETUP on the main remote TWICE to save the settings and bingo, your done!!! Hooray!!! You can now kill your whole family in the car while watching that adult movie while your driving.....
The other way of doing this is by not engaging the parking brake sequence, thus you're inputting the code blindly.
1) Insert the DVD and you'll get the blue screen.
(If you have more than one tv, the unit itself will have the blue screen but the additional tv's you have plugged in will NOT, they will show the dvd menu. Thus you will be able to see the hidden menu on the additional screens after inputting the code, but not on the main unit because of its blue screen.)
2) On the main remote, push stop twice and then 1, 2, 6, 4
3) Push the joystick on the unit SOUTH twice and then click it once.
4) Press SYS SETUP on the main remote twice to save your settings.
Posted on May 05, 2009
What is passcode for my Jensen VM9311TS car stereo?
on main remote push
stop twice, then 1264, joystick south twice, then once, then sys setup twice to save
Jensen vm9311ts dont kno where pink wire goes or anything
go to www.google.com then type JENSEN CODE and get the first option .
2answers
Is a media link box and media module the same for jensen vm9311ts
they are not the same. the media link will work for that model.
2helpful
Need bypass code for Jensen VM9311TS
Here it is how brother,insert a dvd movie,next use the toggle switch sequence to get image,next press stop button twice on the remote,then press 1 2 6 4 on the remote,you will now see a menu that says
Regon Code
Brake Override(I know you are drooling by now)
Macrovision
Loader Version
Model Version
Using the right joystick on the unit,navigate to the options of your choice,click on them to toggle on,off or which region code you want.
This wht you want.
Region Code 1
Brake Override ON
Macrovision OFF
When you are done,click SYS SETUP on the main remote TWICE to save the settings and vingo.
Jensen VM9311ts media module
I have the Jensen VM 9311ts. Where can I get a media module for it? I found the cord and the j link cord , but I can't find a media module anywhere. HELP!
Jensen VM9311TS DVD/CD No sound
sounds like the channels are out or the system has a malfuction on the inside i recommend you return it for a new one.
No memory on VM9311TS
This is almost always related to an installation error. The yellow wire at the back of the unit needs to be connected to a constant voltage source that doesn't switch off with the key. It's possible that the connections to your red and yellow wires are reversed.
Top Jensen Car Audio & Video Experts
ZappaNut
ZappaNut
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
