Televison & Video Logo
Posted on Jul 27, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Picture slightly dims for a few seconds, then brightens to normal
The picture dims fors few seconds and the returns to normal bightness. This happens occasionally. Was first noticed while watching a show recorded on DVR. Seems to happen after the TV has been running for over 1 hour. Not sure if the lamp is ready to go out or could be something else. The LED indicator lights on the front on set blink as if everything is normal when the set is turned on or when switched off.
Marvin
Level 3:
Top Expert:
  • Hitachi Master 85,242 Answers
  • Posted on Jul 27, 2017
Marvin
Hitachi Master
Level 3:
Top Expert:
Answers
85242
Questions
28
Helped
29024947
Points
266281
It is possible that the TV image backlighting is failing.
5 Related Answers
Anonymous
  • 1284 Answers
  • Posted on Feb 01, 2007
SOURCE: My 60" lcd projection tv wont turn on sometimes and throws a lamp light, and if i watch tv for a while and turn it off it wont turn back on and throws the red lamp light
The buzzing sound you most likely hear is the ballast trying to fire up the lamp. I would say replace the lamp and yes they can act up at will. If this is the first lamp replacement ever then you are doing good.
Anonymous
  • 579 Answers
  • Posted on Jan 02, 2008
SOURCE: problems with brightness on the hitachi 50v810
Yes, they dim as they age, and you've done well to get 3 years out of one.
Projection TV makers charge an arm and a leg for their replacement lamps. They make it easy to do but as a result the custom lamp assy is expensive. The trick is to just buy the bulb for your model TV from any number of us aftermarket sources at a fraction of the lamp price and install it in the old lamp yourself. really easy.
Anonymous
  • Posted on Oct 26, 2008
SOURCE: Hitachi 60vf820 ultravision
Thank you so much for your help.
I own a 1998 Hitachi model no. 60EX38B serial no. V8E001713
As I was watching the TV the picture and sound went out.
The next day I turned it on and after an hour it went out again and has not come on since.
I have no video or sound. Would you be so kind and explain what could possibly the problem before I go to the exspence of any costly repairs with the TV being it's age.
Eagerly await your reply
Thank you for all your help
Anonymous
  • 320 Answers
  • Posted on Nov 08, 2008
SOURCE: Hitachi rear projection lcd lp500 series
It is likely the projection lamp is weak, causing the picture to cycle on and off. Take the lamp out and examine the reflector. If it is dull and cloudy, it's time to replace the lamp. A new lamp will have a reflector that is shiny and looks like a mirror. Be sure to rate this solution. Thanks!
Anonymous
  • 1476 Answers
  • Posted on May 12, 2010
SOURCE: colors run; curvature to picture
Your convergence is bad and needs fixed. I have a tip at http://www.fixya.com/support/r4220499-change_projection_tv_convergence_ics which explains the problem, how to fix it and where to get the parts.
Let me know if you need more help.
Thanks for using FixYa and for the generous rating.
hardrocko
Should I fix my TV or buy anew one?
Before you buy a new TV go through all the TV menu options to see if it has automatic dimming depending on the amount of light in the room. If it does it may be malfunctioning and turning that feature off may fix the problem.
1helpful
Picture dimmed. can see the picture and in menu increased the backlight to max but did not go back to normal. checked eco settings and did factory reset. still very dim but can see the picture.
Yah kindly follow this tip. After loosing the back cover when the tv power cord is removed from power socket, check for bulged or defect power capacitors in both the primary & secondary side of the power pack if found any kindly replace it with the actual or equivalent value as this electrolytic capacitor defects is much common for Samsung power packs
2006 Ford Escape headlights will dim then return to normal. Alternator is new and battery is good
Check all battery connections for corrosion or loose wires/ground too, also loose alt belt
2answers
Interior lights and exterior lights are dim, along with heater fan running slow, when first starting car. After a few seconds, lights brighten and fan speeds up. What is it?
For some reason the alternator output is very low when the lights are dim. Something happens to bring output up to normal when they get bright.
Slipping belt, or an electrical problem.
This great monitor has been flawless for the past four years. It is now experiencing a problem which is minor but a bit anoying. The picture brightens and dims slightly in intensity about every 20 - 30...
This problems,there are no fix to it.This problems will continue to happen as the tv in used years after years.As over the years in uesd of the tv.The floorscent tubes incorporate in the LCD screen slowly dimming as the rest of the tv life.
Picture problem
I have an older Mitsibutishi 52" HD 1080. I recently upgraded my cable box to DirecTV HDTV. When I change to format to view in 1080 the TV goes from full screen to what seems to be wide screen with a black bar on the top and bottom. If I change the format to 480p I get a full screen; but the picture has a "redish tint" over it as if looking through sunglasses...I tried everything in my TV manual even call the cable company. Any suggestions?
Toshiba telivisions picture brightens
It has a bad solder connection inside the set. Requires qualified individual to find the connection and resolder it.
Picture problem
Please PM me privately and I'll tell you how to fix this set.
2answers
try cleaning mirror and lens inside
Top Hitachi Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
