Question about Likom Futura LD7 17" CRT Monitor
Lost sound from LIkom HD17a LCD monitor
I had to reload windows on my Compaq AMD Athlon XP 300 and now I can't get the sound from the built-in speakers to work. I tried a seperate speaker system and it worked find. I reloaded drivers for the monitor from Windows update but it didn't change anything. Any suggestions?
It was stupid, the volume on the monitor had been turned all the way down. I checked to make sure it wasn't muted but never checked the volume level. Thanks anyway.
Posted on Apr 08, 2009
Acer mbs8709003
please you att any lcd on load other person and change our system resolution 800 by 600 and att our monitor solve the problem
May 07, 2012 | Acer Aspire M1100-U1402A Refurbished AMD...
I have lost my driver CD. After re-installing Windows XP sound drivers are missing. I want to down load Audio drivers for AMD Athlon(tm) xp200+ 1.66 Ghz , 256 Ram motherboard
You can download the device drivers for your computer from the motherboard manufacturer's WEB site.
I cannot give you the link to the motherboard manufacturer's WEB site because youhave not provided me with the details of the make and model of your motherboard.
Apr 25, 2011 | AMD Athlon XP 2000+, 1.67 GHz Retail...
Pentium III 500 mhz will support windows XP
Here is Windows Xp requirements:
PC with 300 megahertz or higher processor clock speed recommended; 233 MHz minimum required (single or dual processor system);* Intel Pentium/Celeron family, or AMD K6/Athlon/Duron family, or compatible processor recommended
128 megabytes (MB) of RAM or higher recommended (64 MB minimum supported; may limit performance and some features)
1.5 gigabytes (GB) of available hard disk space*
Super VGA (800 x 600) or higher-resolution video adapter and monitor
CD-ROM or DVD drive
Keyboard and Microsoft Mouse or compatible pointing device
Jul 28, 2009 | Intel Pentium III Xeon , 500Mhz...
Can we install windows xp on compaq v3424 au laptop
If your laptop meets the following requirements then there shouldn't be a problem:
CD-ROM or DVD drive
I would take a system restore point BEFORE you upgrade and make sure you back up everything BEFORE you attempt an install/upgrade.
Hope this helps.
Feb 20, 2009 | Microsoft Windows XP Professional With...
Nec 17'' multisync lcd monitor not working properly
What is the problem? Did you try plugging it into another working computer?
Mar 03, 2017 | NEC AccuSync LCD71VM 17" LCD Monitor
WindowsXP SP2Installation hangs in Compaq Presario 2000 series
minimum requirements for XP
• 128 megabytes (MB) of RAM or higher recommended (64 MB minimum supported; may limit performance and some features)
• 1.5 gigabytes (GB) of available hard disk space*
• Super VGA (800 x 600) or higher-resolution video adapter and monitor
• CD-ROM or DVD drive
• Keyboard and Microsoft Mouse or compatible pointing device
Nov 07, 2008 | Microsoft Windows XP Professional With...
Sound card
i could be a realtek sound chip, althouh XP normally has this built in,so go to the link below for the driver. http://www.realtek.com.tw/downloads/ If its not realtek you need to find out the chipset fitted.
Aug 31, 2007 | Compaq (261671-001) Motherboard
Processor
hi, from your reference i could get the info that your pc is running with the mainboard similar to FIC - am37,and with that the below mentioned processors are supported. Recommended Speeds: AMD Athlon? XP 2600+ (266 FSB) AMD Athlon? XP 2400+ (266 FSB) Model 10 w/ 256K Cache AMD Athlon? XP 2400+ (266 FSB) AMD Athlon? XP 2200+ (266 FSB) Model 10 w/ 256K Cache AMD Athlon? XP 2200+ (266 FSB) AMD Athlon? XP 2100+ (266 FSB) Model 8 AMD Athlon? XP 2100+ (266 FSB) Model 6 AMD Athlon? XP 2000+ (266 FSB) Model 8 AMD Athlon? XP 2000+ (266 FSB) Model 6 AMD Athlon? XP 2000+ (266 FSB) Model 10 w/ 256K Cache all the best.. sreejith
Jul 16, 2007 | Compaq Athlon XP 2000+ , 1.67 GHz...
Likom HD17A blacks out
Just check that your monitor is not set to power down(Control Panel> Power Options) and check that the 'Turn Monitor Off' Power Scheme is set to never and turn off any screensaver to see if it still goes off.
Oct 24, 2006 | Likom HD15A 15" LCD Monitor
Likom Futura LD7 17" CRT Monitor Logo
164 people viewed this question
Top Likom Computers & Internet Experts
Ekse
Marvin
Marvin
Are you a Likom Computer and Internet Expert? Answer questions, earn points and help others
