How to hard reset to DWL 2700AP
SOURCE: dwl-2700ap problems
hello!
-- try to change channel and enable security on your wireless network
-- remove other wireless devices on the network because that may cause wireless intermittent in your network
SOURCE: DWL 2700 AP wrong firmware install
hi...
since you upgraded a different firmware try updating the firmware again with the correct firmware if it works fine if it doesnot then the router had gone bad,,
and for GeminiBS reset the router to the factory default since the firmware was not done in a proper manner may be it had interruptions..once the hard reset is done the computer is restored back to the default so that you can use the device..
vedhick
SOURCE: Reset DWL 2700AP to factory defaults
Hi dear try to flow this tips it will help you
Administrator Settings
Administrator settings allow you to customize User Name and Passwords as an Administrator of DWL-2700AP. The default value of the Username is "admin" with no password entered.
Password
Enter a password in the Access Point Password field. Type the password again in the next field to confirm it. The Password is case-sensitive ("A" is a different character than "a",) and must be between 0 and 12 characters in length
System Settings
You may reset the DWL-2700AP back to factory settings by clicking on Restore Default settings.
Restore Default Settings
Choose Yes and click Apply to restore all Access Point settings to the factory default settings.
Thank you
Imran
Pls rank as possible
SOURCE: DWL-2700AP reset default settings
Remove 13 screws from the perimeter of the back side of the DWL-2700AP and pull the covers apart. On the inside along the bottom adjacent from where the network cable plugs in, you will find a reset button. It is next to the white plug that leads to the antenna. You will need a flat screwdriver or something thin and sturdy to wedge between the casing and the reset button. While the AP has power, press the button and hold it in for a few seconds then release. Give it a few minutes and the factory defaults should be restored. Default IP: 192.168.0.50, Default subnet mask: 255.255.255.0
SOURCE: How to probe the configuration or reset the 2700AP?
thanks for all the supprot...i tried your sugestion and did the same...i could now borwse internet but i cannot access the D-Link configuration website using 192.168.0.50...nothing is coming
