The color correction options in the menu are limited and I can't figure out how to get the color corrected. I can only seem to get yellow, blue and an overall green tint.
Sounds like you are using an analog standard VGA cable interface. Since the menu has the correct coloring, it is not the monitors fault. Check the connections of the video cable at each end to ensure they are tight and not kinked. If they are ok, try using a different video cable. If thew problem still exists after that, it is probably the video card in the computer.
There is a problem with the connectors desoldering in the tv. My mother in laws tv did this after 2 months. Should be warranty issue if less than year old
It could be the tint settings on your TV. Check your TV's settings menu for color/tint options. If you can't find it, break out the manual and look in the index for tint or color, then locate the page and it'll tell you how to get there.
Make sure the tint slider is in the middle, 0 or 50%, depending on your TV.
Best of luck.
Remember to rate my solutions! If you have time, drop a testimonial too -
they really make my day. :)
THERE ARE ADJUSTMENTS TO THE VIDEO DRIVE THAT CAN CORRECT THIS PROBLEM/THEY ARE IN THE SERVICE MENU. WITH THE POWER OFF, PRESS MENU-5-VOL+ POWER THE SET WILL COME ON IN THE SERVICE MODE. STEP THREW THE MENU ITEMS UNTIL YOU GET TO RED/GREEN/BLUE DRIVE THEN ADJ. TO BALANCE THE COLORS WHEN DONE PRESS MUTE TO STORE THEN POWER OFF ON THE FRONT OF THE SET OR IT WONT SAVE.
Go to menue on controller, then Picture, then adjust Color and Tint to you taste. The color ajusts Blue and Green move left more blue move the slider right more green. The Tint controlls red. More red move right less left. Also chech Color temp setting.
Hopefully someone on here has a manual and can tell you exactly where the tint controls are. Also need to try adjusting the color level, turn it clear down so you have a black and white picture.
Is the picture still green over the screen with the color control
set clear down to black and white? If it does, you might
have an issue with the green gun going out or problem in the
circuitry to it.
By the way, the best way to adjust the picture settings on a
tv are to first turn the color control clear down, then adjust
brightness and contrast for best black and white picture, then
bring up the color level to where it should be and adjust the
tint for best red/green ratio.
HI PLEASE ADJUST THE SCREEN CONTROL OF UR TELEVESION SET IT IS INSIDE THE TV..IF U KNOW THE SCREEN CONTROL IN THE SET THAN MAKE IT LITTLE ANTICLOCKWISE.AND THE SET WILL BE OK..
