Question about Mitsubishi WS-55513 55" Rear Projection HDTV
Shuts off after 15 minutes
I have a WS-55517. After 15 minutes it turns off. While turned on the picture seems to decrease in size just slightly then it goes back to normal screen size .
Posted by wik3garcia on
  • wik3garcia Apr 15, 2009
    Thats exactly what I did. They said they have to rebuild the signal board. Thx.
Paul Buscema
  • 116 Answers
Most likely you have picture tube coolant leakage on the power board. Have an authorized Mitsubishi service shop take a close look.
Posted on Apr 15, 2009
Sanyo 24 in flat screen model DS24425 Screen slowly goes fussy and slowly goes black , a slight tap on the rear left side brings the picture back to good screen,for a few minutes or a couple of hours no...
Hello
Your flat panel TVs picture tube base board has soldering loose contact with it. Just unplug your TV from AC mains socket, and open it. Pull out the picture tube base card from the picture tube neck. Pull it out straight, no shake must be there, as it will damage its connecting pins.
Normally, loose sodering are very difficult to loacate, as they will be quite micrscopic in size. Just resolder all the suspected loose sodering point on that board, by applying a little more solder. This will solve your TVs problem. OK.
May 26, 2011 | Toshiba 55ZV650U 55 in. LCD HDTV
After researching online, my TV problem seems pretty common. TV - Mitsubishi 1080 series WS 55511. Green blinking light blinks for 3 seconds, then goes out and TV never turns on, but I hear a slight...
The green light is known as "The blinking green light of death". This refers to the green LED on the front panel of the TV that normally blinks when turned on after a power failure or when unplugged: the green light is supposed to flash for about 1 minute while both microprocessors boot up: If it won't stop blinking it means that they aren't communicating w/each other. Unfortunately, it's common in Mitsubishi & other RP TV's. Getting this fixed by a professional is around $6-700 with labor, parts, etc. It's really not worth it in my opinion. I would go out and buy an LCD or an LED TV.
Nov 28, 2010 | Televison & Video
Turn the TV on and a minute after the picture comes on the picture scrunches up to the top of the screen and colors are distorted. It the goes black. I turn the TV off and on and the picture is sometimes...
try to tap your tv slightly at the side if it go back to normal operation you have a weak solder commonly in the main board try to resolder parts that is slightly hung.
Oct 15, 2010 | Sony Televison & Video
TV screen goes blank but power stays on
Sounds like the CRTs are going into protective blanking due to the vertical output ic needing to be resolderd. Try resoldering the vertical IC that may possibly fix the issue.
Jun 15, 2008 | Mitsubishi WS-73713 73" Rear Projection...
Wavy picture
This EXACT thing just started happening with my WS-48513. Anyone have any ideas?
May 18, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Projection TV when turned on picture is dark can view slight images until dinning room light is turned on
Try hooking the TV to a different outlet fed by a different breaker. Does the problem go away? If so, the culprit may be a wiring problem in your house that is causing the TV not to get enough power unless the dining room light is on.If in doubt, consult an electrician to make sure both the dining room light and TV outlet circuits are working properly.
Mar 06, 2008 | Mitsubishi WS-55613 55" Rear Projection...
Mitsubishi platinum plus ws-55857
Solder connects = temporary fix.......Replace IC's..best
order two STK392-570 good quality.....16 to 22.00 each
...............................T.
Dec 26, 2007 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi WS-55513 55" Rear Projection HDTV Logo
139 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Muntejaya Ginting
Muntejaya Ginting
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
