Sony Ericsson K510i Cellular Phone Logo
Question about Sony Ericsson K510i Cellular Phone
Voice Message Phone is showing I have a voice message but I cannot access this message or delete the logo showing the message. Went into voice but it said I had no message.
Posted by steveguk24 on
Anonymous
  • 425 Answers
Hi
try resetting your phone to factory settings.
if samething happens have it reprogrammed...
hope it helps...
Posted on Oct 16, 2007
I have a Panasonic home phone and I'm getting this message. New voice mail pressVM I press VM and get msg call service provider for access#
Your Panasonic phone has no voice mail associated with it; voice mail is entirely a function of your phone service. You need to contact your phone company and ask them to reset your access code, and also ask them how to access your voice mail and do things when you are in voice mail, such as delete or save messages, change your announcement, etc.
I forgot how to clear the stored voice mails
Les,
If you want to delete the actual voice mails, you have to go through your phone company (using their keypad commands) since voice mail is only accessible through your phone (but the voice mail messages are stored through your phone company provider).
Info from the Uniden DECT 6.0 6035 Manual:
Using the Voice Mail Service If you subscribe to a voice mail service, you can use your phone to access your voice mailbox. The new message LED on the handset ?ashes and VM appears in the handset display whenever you have messages waiting in yourvoice mailbox. When you subscribe to the service, your voice mail provider provides you with the access number and the required voice mail signaling tone. You can use your phonebook to store the access number.
Resetting the Voice Message Waiting Indicator
When you receive a new voice mail message, the new message LED on the top of the handset ?ashes and
appears in the handset display. In the event your message alert tone gets out of sync with your phone company's voice messaging system, you can reset back to its original "no messages waiting" state. To reset, press and hold [?nd hs] on the base for ?ve seconds. A beep sounds and the message alert tone is reset.
Here is the manual:
Uniden 6035 1 Owner Manual
How to leave a voicemial message
There are three elements to voice mail; having a Panasonic brand voice mail system, recording the greetings, and setting call forward conditions. Which ones have you done?
The default access to voice mail is extension 500 on the intercom, but we used to use 165. When you dial it, the lady says "welcome to the Panasonic voice processing system". If she doesn't or you're asked for a password, or you have not done the tutorial, then you need to do that and it guides you to the setup of the greetings, name, and password change. After that, you dial *710x 500 (or your VM access) # on the inercom to set call forward to voice mail, with 4 being no answer (my preference since it gives me the option of answering the 2nd call or letting it fall to voice mail), or 5 for Busy/No Answer.
The message manager (mailbox 998) and the system owner (mailbox 999) has the ability to access and change how the voice mail system performs. The owner can change your name for the directory or reset your password and/or
setup or delete your mailbox.
Carl
I need to change my voice message
1 Call your Motorola voice mail service. Press the "Contacts" or "Address Book" button and select the "Voice Mail" entry. Press the "Call" button.
2 Enter your password. Call the service provider for your Motorola phone if you cannot recall it.
3 Delete all voice mail messages. In order to access the main menu you'll be required to empty your inbox.
4 Select "Change Personal Options," then choose the "Change Voice Message" menu. Disconnect the phone call to save your settings.
2helpful
Deleted voice mail in error, is there anyway to retrieve?
  • Start by tapping the "Phone" icon on your iPhone.
  • 2 Next, access your voice mail messages by tapping the "Voicemail" icon.
  • 3 Look at your list of current voice messages. If you have any messages that are eligible for recovery, you'll see an item at the very bottom called "Deleted Messages". Tap on this to access a list of your deleted messages.
  • 4 You should now see a list of deleted voice messages. If you see the message that you want to recover, tap on it and choose "Undelete".
  • 5 Your voice message will now be sent back to the main list of current voice mail messages.
  • 6 Repeat steps 1-5 for "each" message you wish to recover. This may take time!
  • Read more: How to easily recover accidentally deleted iPhone voice messages ' eHow.com http://www.ehow.com/how_4707121_accidentally-deleted-iphone-voice-messages.html#ixzz1A58SmNWv
    How do I set up voicemail? New phone, mailbox says it is full, how do I delete messages?
  • Access the main menu of your Samsung Go Phone. Hold the #1 key down until you are connected to the voice mail system. If for some reason pressing the #1 key doesn't connect you to voice mail then call customer service at 1-800-331-0500. You will be connected with an operator who can help you troubleshoot the voice mail problems on your Go Phone.
  • 2 Follow the voice prompts and select "Listen to Messages" from the list of options. Bear in mind that checking voice mail on a Samsung Go Phone will count against your prepaid minutes.
  • 3 Once you have finished you can select the "Delete Message" option from the voice prompt if you wish to clear your voice mail messages. If not, you can simply press "clear" or hang up the phone to leave the voice mail system.
  • 1helpful
    I had a voicmail that I had saved on my phonen I went to listen to it, it was automatically deleted. That is a very imprtnt voicemail that I needed. Is there any way to get it back?
  • Read more: How to easily recover accidentally deleted iPhone voice messages ' eHow.com http://www.ehow.com/how_4707121_accidentally-deleted-iphone-voice-messages.html#ixzz1A0684OUB
    Phone is showing there is a voice mail message
    You have unheard messages on the voicemail system provided by your telephone company. This system records messages when someone calls while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
    Voice Recording Full
    Depending on how your razr is set up, you should be able to click on the "settings" button, then click the "tools" option, which will open that sub-directory, then scroll down to where it says "voice records", open that, and then click the menu bar (the one that looks like a flat bar like --- ) and then it should give you the option to delete it.
    4helpful
    3answers
    "New Voice Mail" stuck on screen.
    Hi, I have the same problem. I called the service provider, they left a voice message, which I accessed later and deleted from my voicemail box. This took care of it and I dont have that message on the screen now. I think you can just leave yourself a voice message and access it later and delete it. That should resolve it.
    Top Sony Ericsson Cell Phones Experts
    Marvin
    Marvin
    Sean Wright
    Sean Wright
    Kolbrun...
    Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
