SOURCE: BELL HOWELL 17462 PROJECTION SET TV SCREEN WENT BLANK
Do you still have sound? Can you see light at the back of the set when the screen is blank -if so the bulb is ok and you've just lost video.
SOURCE: I bought an old Bell & Howell 253 AX and take-up isn't powered
Have you switched the switch on the front? It is black and about 1 1/2 inches tall. Don't worry I had the same problem at first with mine!! ;) I hope I can help!
SOURCE: Bell & Howell Floor Lamp
This is probably a simple fix. There is not much to floor lamps. It is usually a bad switch. I would go to www.google.com and type in electrical contractors your city and state. Any electrician should be able to fix it rather easily. It will be cheaper if you take it to them. If you would like to repair it yourself, I can give you a way to test and fix yourself.
SOURCE: I have a bell and
Remove the memory card from the slot from your camera. Then insert back and check you will not be getting this error.
If still there is some problem, take the memory card out and copy the pictures from the memory card to system and then format it. Insert the card back to the camera. You won't get the memory full error.
If you still get the error then you need to do factory reset in your camcorder.Go to settings-->>default settings-->reset.
Hope this helps.
If you still have any queries feel free to ask us.
Shane
