SOURCE: Samsung Prostar 816
The battery is dead and will not maintain system programing after a power outage. If the battery is not replaced this problem will occur everytime the power goes out.
SOURCE: PROSTAR 816 PLUS
First to change the clock to a 12 hour instead of a 24 hour requires a bit of CAUTION. You have to go into the technician level of programming so be careful. From a display phone, Press #, ( Programming ) is displayed, enter 20, ( MMC Disabled ) is displayed, enter password ( 1 2 3 4 is default ), enter function 4 for 12 hour clock, enter # to exit. If the time and date are displayed wrong you have to go to # 55 and reset time and date.
YY MM DD W HH MM format. W = Day of week with 1=Monday and HH MM must be entered in Military time even though you have a 12 hour clock set. Good Luck
To change the ringing on a prostar 816 you first need to be at a display set (doesn't matter what the extension number is).
with the handset down enter #20 the screen should say MMC DISABLED
1) enter in 1 2 3 4 1 # (that enables programming)
2) enter in #62 the screen should say day ring assn
3) press the line you wish to program
4) press the buttons for the extensions that you wish to ring (the ones in the right next to the handset)
5) press # when finished with the line
6) repeat steps 2 through 5 for the remainder of the lines you wish to change
The code for hold recall is #52
enter in your hold recall time in sec. and in a 3 digit format. i.e. 30 seconds = 030 a minute and a half is 090 and so on.
it sounds like the memory battery on the main board is no longer working which means that it'll happen again.
SOURCE: How do I increase the hold time (before it starts
To change the hold recall timer on a prostar 816 you first need to be at a display set (doesn't matter what the extension number is).
SOURCE: I have a prostar samsung 816 plus and we have a
with the handset down, enter #20 the screen should say MMC DISABLED
press # when finished.
