Friedrich QuietMaster RS10J10 Air Conditioner Logo
Question about Friedrich QuietMaster RS10J10 Air Conditioner
Leaking water The air conditioner unit is spitting water when turned on
Posted by bubblez on
  • Madyarka Jul 23, 2008
    My air conditioner is spitting up water and making a crackling noise. Water is accumulating in the front of it (when I open the front cover i can see it at the bottom when I remove the filter). I removed the window unit - hosed it down, cleaned it out and it's still doing this. Need help - am clueless.
Anonymous
  • 86 Answers
Water leakage from indoor unit
1.clean cooling coil
2. wash air filter
3. check drain tray.if it block then clean it
4. check drain pipe U band.
5.check indoor unit water tray.if damage change by new one or repair it
Posted on Mar 15, 2008
Oscar Netto
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 110 Answers
Most airconditioners drip water outdoors. Is yours doing it indoors??
Posted on Sep 07, 2007
5 Related Answers
Anonymous
  • 203 Answers
SOURCE: air conditioner is leaking but lights not blinking
Make sure the drainage port is closed as per the instructions. If you continue to have leakage you may have a leak in the tank.
Posted on Jun 15, 2007
dcp2
Daniel Phillips
  • 63 Answers
SOURCE: Water leaking from portable air conditioner
Sounds like the drain line is blocked you would have to take this unit apart in order to check this. I would use a can of air to blow out the leakage. Also make sure the unit is level
Posted on Jan 25, 2008
Krazytech
Franklin Ouchida
  • 725 Answers
SOURCE: LG air conditioner spitting out water through vents
Hi Mia
I would worry about coolant .. your problem is that the drain in on the outside is pluged or the AC is not installed correctly and is not draining to the outside as it should...
hope it helps
let me know
Posted on Apr 09, 2008
Anonymous
  • 53 Answers
SOURCE: My air conditioner unit is spitting out water
You have to recheck your installation. The unit should be installed in such a position the condensed water runs out to the drain pipe and goes out. Please first adjust the position and ensure that the front grill portion is kept higher than the rear portion allowing water to flow out to the drain pipe.
Remove the drain pipe and clean it so that there is no dust or insect blocking the free flow of drain water during condensation.
The above would enable your ac unit to throw cool breeze and not water!
Posted on Jul 10, 2009
Anonymous
  • 767 Answers
SOURCE: Air conditioner unit is leaking water from the bottom
Hello my name is Heath it will be my pleasure to assist you. First use a level and make sure the unit is level front and back and sisde to side. Next be sure the drain hose is not plugged or stopped by any debris.
Posted on Jun 03, 2010
3answers
My unit is making a loud noise and is spitting water out with the cool air
i have had units turned too cold and ice forms on coils. shut unit down and take it out of window. turn /tilt and when all water runs out, re install and turn back on to a Higher , less cold setting.
Water is spitting from vents and leaking. i drained the unit but it continues to spit drastically.
These units condense moisture,dehumidifying the air which is good!
They move a lot of air as well, and generally are unfiltered and even filtered
the litle channels for the water to escape to the rear of the unit(outside)
will clog up in their drainpans, the channels are shallow and the drain pain
must be level or biased a tad to the outdoors. The units condensate is to be
routed to the rear where the fan blade has a splash ring on it that splashs the
water on the outside coil. These really need to be removed every other summer at min
and chemically cleaned with condenser coil cleaner that strips the coil clean with a mild acid
to work well
2answers
Window air conditioner is spitting water
Hello, usually a window AC will spit water if the unit is not tilted back or if the drain is backed up, if the unit is level try tilting it back it the window somewhat. Also, if the unit does have a drain make sure it is not blocked.
1helpful
Spits out water from the indoor unit
indoor coil icing up .gas leak the water is from the dripping coil . or you have left unit on for to long on a low setting
3helpful
Water in air conditioner
A lot of the newer window units design the outside fan to pickup the condensate water and sling it onto the coil. The evaporative effect makes the unit run more efficiently. They ususally don't spit, but if the unit is running well, otherwise, I would't worry about it.
Hi Mia
hope it helps
let me know
13helpful
5answers
Top Friedrich Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Tim Whalen
Dennis Boxerman
Are you a Friedrich Heating and Cooling Expert? Answer questions, earn points and help others
