I have a nuvi 250w that is 5 months old and it will not turn on. It was working fine and I left it plugged in to my car charger for an hour and when I returned and tried to turn it on it would not turn on. I thought maybe the charger went bad so when I got home I used my USB cable to see if it needed to be charged but no change. Only had unit for 1 day....just replaced the exact same unit for this one...it had the same problem. Won't turn on with any power source
I had the very same problem with my 250w. After trying to push the reset button while holding "on" (which didn't do anything at all), I decided to open it. If you have a valid warranty, I'd recommend sending it for repair. Anyway, since my warranty was over, I unplugged the battery and replugged it. Miraculously, the device turned on.
If you intend to open it, here is how I proceeded:
-Remove the sticker strip (which covers the reset button)
-Unscrew the 2 screws (you'll need a special screwdriver, T6)
-Open the cover (carefully, there are wires holding the 2 pieces together) with a flat screwdriver (the most difficult part)
-Once you are done, unscrew the 3 screws that you see on the back cover to reach the battery. Then unplug the battery and replug it.
-Once you've done this, you can immediately check if it turns on.
I hope this will somehow help you.
Thank you kind sir. I am driving to Montreal as I speak and got this problem. I didn't realize there was a reset button...
thanks again...
I fixed mine too, Thanks DrakeDragula.
I love internet! Great solution, thanks!
Have you tried pressing the reset button on the bottom of the unit where the decal is?
- Jim
SHARCNET-USA
