Purchased display screen to replace screen that was blanking out in bottom 1/3. Not sure how to replace the screen; frame around new screen has different tabs. Is there an easy to understand guide/manual on how to replace the display screen? Thx!
ManualsBack to Contents Page
Display Assembly and Display LatchDell Inspiron™ 6000 Service Manual
Display Assembly
Display Bezel
Display Panel
Display Latch
Display AssemblyRemoving the Display AssemblyCAUTION: Before you perform the following procedures, see the safety instructions in the Product Information Guide.NOTICE: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as the back panel) on the computer.NOTICE: To avoid damaging the system board, you must remove the main battery before you begin working inside the computer.
grounding wire screw
5
routing channel for antenna cables
display cable connector
6
system board connector
antenna cables (2)
7
routing channel for display cable
M2.5 x 5-mm screws (4)
Â
Â
Replacing the Display AssemblyConnect the display cable to the system board connector, and route the display cable in the cable-routing channel.Â
If a wireless Mini PCI card is installed, re-route the antenna cables and connect them to the card.Â
Replace the keyboard.Â
Replace the hinge cover.Â
Removing the Display Bezel CAUTION: Before you perform the following procedures, see the safety instructions in the Product Information Guide.NOTICE: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as the back panel) on the computer. NOTICE: To avoid damaging the system board, you must remove the main battery before you begin working inside the computer.
NOTICE: Carefully separate the bezel from the display assembly to avoid damage to the bezel.Follow the instructions in "Preparing to Work Inside the Computer."
Remove the hinge cover.
Remove the keyboard.
Remove the display assembly.
Remove the six rubber bumpers.
Remove the six M2.5 x 5-mm screws from around the display assembly, and remove the display bezel.
Use your fingers to separate the bezel from the display assembly by lifting the inside edge of the bezel away from the display assembly. Pull the bezel from the top edge toward the center of the panel to open the snaps.
http://support.dell.com/support/edocs/sy...
I will be grateful if you can give proper rating to the solution.
Thanks,
PREM
You should have to buy a compatable LCD and you can only get it from DELL Sales. Call 1800-624-9896
Thx for all the advice. However, the problem is that the old LCD has fastening points at the top & on the bottom for the inverter, but the new LCD doesn't have those. Does that mean I bought the wrong replacement LCD? And if so, how do I specify exactly which replacement one I need? Thx again:)
