Question about Vulcan Heating & Cooling
SOURCE: Have a 20yr + old vulcan gas heater and I cannot turn pilot off
Hi, If you are talking about the knob on a gas valve that you use to light the pilot and turn it off also, you have to turn the knob either ccw or cw to turn it off. To light the pilot is when you turn the knob to pilot and push down and hold it, light the pilot while you continue to push it down for a minute, and then slowly release it and pilot will stay lite. So, if this is the type you have just turn knob one way or the other and it will shut off. If you do not have this type set up, just turn off the gas to the furnace at the flex line as there should be a hand valve by code and by law that supplys gas to you're furnace. You can shut it off there and the pilot will also shut off.
Sincerely,
Shastalaker7
PS If you don't have either one of these shut off's, on the main gas valve it self, you should have a place marked pilot adjustment. Pop the small chrome cap and insert a very small screw driver to turn it cw to shut off pilot.This would be you're last choice.
Posted on Jan 19, 2010
SOURCE: pilot on, gas fires up, no fan comes on.
Sounds like you are talking about the indoor fan that circulates air through house. Turn the unit off and make sure the fan rotates freely. Next check the capacitor for the fan. If it looks swollen its probably bad. If it doesn't look swollen then you will need a multimeter to check it with. If that's ok then check the fan relay. Let me know what you find.
Posted on May 30, 2010
SOURCE: Hi I have Vulcan
When on, Is the pilot strong and blue flame? If its yellow the flame is being pulled away from the T/couple or Pilot generator it will cause the unit to shut down.If the pilot light is strong it could be the T/couple or pilot generator.
It could also be the high limit switch kicking the pilot off but that's usually the case.
you should have atech look at the problem as there are other reasons that could effect its operation
Posted on May 12, 2011
SOURCE: Hi, Vulcan " burwood " gas space heater.I have
As long as the burner works it is unlikly that the thermostat is your problem. It is more likly the fan limit switch needs replaced.Unfortunatly I am having no luck finding a wiring diagram for this model so I can't tell you where it is at,but I think that's the problem. Thank you. Sorry I'm not more help
Posted on May 19, 2011
Testimonial: "Hi frodo,Thanks for the quick response i will try the advice you mentioned. I will let you know if this works.Thanks again. olmate 56"
SOURCE: I have just moved into
Hi Please click on this link to buy its parts. Hope this
helps...please post back with its complete model no for further assistance. Daniel
Posted on Sep 14, 2011
Apr 11, 2013 | Heating & Cooling
May 19, 2012 | Heating & Cooling
Jul 01, 2017 | Vulcan Heating & Cooling
Sep 11, 2011 | Vulcan AUW230A Heater
May 19, 2011 | Heating & Cooling
Aug 09, 2010 | Vulcan AUW230A Heater
May 30, 2010 | Heating & Cooling
Apr 30, 2010 | Cozy Enclosed Front Console Heater 20,000...
Apr 07, 2009 | Dayton (4LX41) Heater
Mar 16, 2008 | Heating & Cooling
24 people viewed this question
