Question about Sony PlayStation Portable (PSP) Console
When I turn on my PSP the cursor is stuck to the
When I turn on my PSP(fat) the cursor is stuck to the right, when i push left on the d-pad it goes right back to the right. I haven't had any previous problems.
Posted by spidermask03 on
Anonymous
First try wiggling the little thumbpad thing around and if that doesnt work try taking the top of the thumb thing off and cleaning under it then wiggle it
Posted on Apr 06, 2009
1helpful
When I turn on PC cursor is in middle of screen but moves slowly to top and gets stuck there...can only move left or right
need a new mouse if its a pc and if its a laptop, you may need to replace the tracker pad
2answers
Psp 3000 D pad problem...
I think this is something you can fix, the problem is simply a stuck button. If you can open it up and find the area on the board that's under the D-pad, you should be able to unstick the button by wiggling it a little.
3helpful
PSP directional button going crazy but button is not stuck
the analog button contact pad maybe loose or the body fixing screw maybe loose.
13helpful
2answers
My toshiba laptop cursor doesnot move when i touch the tray pad
Hi!
I had the same problem after my fat cat sat on my keyboard. This is how I fixed it. At the top of the keyboard there is a F9 key. If you look closely at this key, it also has two pictures of the mouse pad. This key is a toggle that turns the mouse pad on and off. Down near the lower left corner of the keyboard is a key marked FN. Hold down the FN key and press the F9 key. That will turn the mouse pad back on.
BTDT, HTH
The left button on the d pad on my psp is stuck!
you would probably have to fix your joystick(by pulling it apart) if you cant to that carry it to someone
1helpful
4answers
Psp scrolls down and left Help Plz
Your directional pad is sticking. you can buy a replacement cheaply on ebay
D-pad
I think the only solution for this is to replace the entire d-pad.
Erratic cursor
It happens with both? Sounds like it may be a driver or motherboard issue.
Check the HDD for errors with Checkdisk (Start -> Run -> cmd -> Ok -> chkdsk /f
Try redownloading the touchpad/mouse drivers from the Toshiba site
2answers
Stuck cursor
you can try using air in the can to clean your stick but you may have to open ur psp up and clean it that way.
3answers
Im stuck
you have to open it up and look at the d pad the rubber might be worn or damaged you can easily get replacements on the internet and they will do it for you if you want
Sony PlayStation Portable (PSP) Console Logo
Top Sony Video Game Consoles & Games Experts
Ekse
Oloyede Monsuru
Muzahura Frank
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
