Samsung SCX-4216F All-In-One Laser Printer Logo
Posted on Sep 04, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Recieving a fax
I know there is a fax ready to peint but the screen is saying, line error
HEMANT GROVER
Level 2:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Samsung Expert 171 Answers
  • Posted on Oct 26, 2007
HEMANT GROVER
Samsung Expert
Level 2:
Cheetah:
Answers
171
Questions
0
Helped
118569
Points
243
TYPICALLY LINE ERROR MEANS , PHONE LINE IS DISTURBED,
YOU SHOULD GET PHONE LINE CHECKED OR ADJUST SIGNAL LEVEL PARAMETERES IN THETRECHNICAL MODE
OMNIPRESENT
Anonymous
Level 2:
  • Expert 161 Answers
  • Posted on Sep 21, 2007
Anonymous
Expert
Level 2:
Answers
161
Questions
Helped
103747
Points
283
Try turning the ECM off. It belongs to the FAX SETUP menu and is explained in the user's manual.
  • rupchan thapa
    rupchan thapa Dec 27, 2014
    hel me for samsung 4521f fax recveide seting not sering
2answers
Sf5100 says recieve error
take the power out and hold the red button in. put the power back
1helpful
Our fax machine says recieve error and will not recieve faxes
I presume the machine has its own telephone line. Lift the handset and make a telephone call. Can they hear you ok? Can you hear them OK? If both ok then have them ring the fax and you answer it with the handset. Can they hear you ok? Can you hear them ok? or can you hear crackle on the line or any other strange high frequency noises? If you hear these noises then your telephone company will need to clean the line. Thats usually why this problem arises. the SF5100 was Samsungs best fax in my opionion. It did not suffer from any problems except wear and tear like all machines.
I HAVE TRIED TO FAX BUT I KEEP GETTING ERROR 344 THE FIRST PAGE GO THROUGH AND THEN IT TELLS ME FAX FAILED I'VE TRIED 5 TIMES THE RECIPIENT SAY THE FAX IS READY TO RECIEVE
The remote machine has failed to respond to a fax command from the local machine due to the connection being interrupted or:
The remote user has pressed the Stop key while the reception was in progress or:
Under rare conditions incompatibility between the two machines may cause the remote machine to simply abandon the call.
Solution:
1. Reattempt the fax transmission at a different time when telephone line conditions have improved.
2. If the fax session was using error correction, disable ECM if not already.
2answers
My fax machine is not sending faxes but will recieve faxes it copies the pages to send then dials but once it connects it drops the call and gives a error message on the screen then tries to redial a...
Reset all settings of fax to factory defaults.
For that press menu button of printer and enter in fax settings reset all settings to defaults.
Then restart printer.
Also change phone line cable Then check.
My chat session is disconnected because of power failure .
Let me know if you need further assistance.Thanks.
Same problem
press the setup button and scroll down to tools.
in tools there should be an option that says run fax test.
that would give you a printed page as to which part of the hardware of the printer or the fax line failed.
What your error code means is(look below)
Definition
There is too much noise on the line for a valid connection between two fax machines to complete. The noise problem might go away over time.
Solution
Retry the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve.
My PC 201 fax machine says error 2001 when I try to fax pages. When I first put the pages in and enter the phone number it says ''recieving'' even though I'm sending not recieving. And then the pages run...
This type of error is generally caused by interference on the telephone line, an incorrect telephone line connection, or an alarm system or other device on the line.
1) Try re-sending.
2) Try connecting the machine to another phone line.
3) Have the line checked.
You did not say if this was a newly occurring problem. Regardless, take a look at this setup procedure but if you don't have a user's manual, contact Brother's support before altering setup:
http://support.brother.com/g/b/faqend.aspx?c=au&lang=en&prod=mfc7362n_as&faqid=faq00002728_005
You might try the chat or email at the support site as well.
Contact Brother
Can only recieve some faxes
this sounds like may be there is a phone line problem on those two machines or that line is there dial tone??may be you need to have local phone company check this out
1helpful
MFC -9420 CN Printer/Fax Scanner
I've seen this before...
The machine is calling for legal sized paper and it thinks it has it in the paper tray. Check the back stop that is inside the paper tray. It should be a green guide that is closest to you if you pull the tray out. You may have to lift up a flap on the end. Make sure that the paper stop is on the correct paper size for what is in the tray. Hope this helps. Let me know if you need any more assistance.
If this helps you please rate it as Fixya!
21helpful
6answers
Error 232 receiving fax
fax error 232 indicates a communication failure between the sending and receiving units. I'd check for line noise on the phone (you can hear it as cracks and pops) If your fax line is not dedicated, any noise from another phone pickup or an answwering machine can cause the failure.
2answers
Canon fax 2060P not recieving faxes
It seems that the protocol is failing. Just check, by printing a receive report. If there are errors it is after the check frame. If no errors, it is failing before the check frame. In either case, 1st aid is to listen using a handset for noise or static on the line. If the line is clear, then you will have to call service to change the tx/rx attenuation.
Top Samsung Office Equipment & Supplies Experts
Marvin
Marvin
Norman Weimar
Norman Weimar
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
