Question about Mitsubishi Diamond Pro 900U 19" CRT Monitor
Activate usb ports on back of monitor
Summarize says it all, I'm a newbe.
Anonymous
Activate usb ports on side of hp monitor
Posted on Apr 16, 2009
Anonymous
Friend fixed it. thank you. uts
Posted on Apr 06, 2009
Usb ports dont seem to work
In order for the usb ports to work you must have 1 usb from the computer connected to the monitor. The monitor may have a specific input port from the pc in order to activate the other ports on the monitor
1helpful
Usb ports do not work
I have a 24" Dell monitor with built-in USB and SD sockets. Sometimes I have had problems with these not being responsive. This usually comes down to electrical connection.
You should do these in order, also testing for USB port availability at each step .
#1 is the monitor powered up? (USB is active only when monitor is switched on with power button on front of bezel)
#2 check that the USB cable at both ends is plugged in! (you need electrical connectivity)
#3 check that the USB port on the PC can see another device like a memory stick
#4 check your PC's software (drivers must be loaded and the USB port recognized)
How do I activate the USB port on my Monitor?
Make sure it's plugged in to a USB port on the motherboard and check device manager to make sure the device is detected. Also might need drivers. If any disc came with your monitor you may wanna run that.
Forerunner 305 "problem receiving activities"
I've had this problem. First -- and this sounds weird -- use a USB port on the back of your computer. Do NOT use a "secondary" type of USB port, such as an add-on hub, the ports on the front of a desktop machine, ports built into peripherals like a monitor, etc. Apparently, all USB ports are not created equal. Second, make sure you've the freshest Garmin Communicator plugin (which may entail a fresh download/install).
How to I activate the USB ports on my DELL monitor
All you need is an USB cable from you PC USB post to the USB input port on the monitor, it is just a USB hub on the monitor, there is no software needed.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV, Monitors, Caps : http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitor kits: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Please post back what you find.
Why don't the ports on the monitor work?
This monitor has 8-port USB hub that the USB input of the monitor must be connected to the PC USB port. There are fuses for the USB port also to protect the 5VDC output at the USB ports.
Document:
http://support.dell.com/support/edocs/monitors/1704fpt/en/about.htm#Specifications
I do not know how to make my dell monitor usb ports active please help me
  • Check that your monitor is turned ON.
  • Reconnect the upstream cable to your computer.
  • Reconnect the USB peripherals (downstream connector).
  • Switch off and then turn on the monitor again.
1helpful
USB ports in monitor fail intermittantly
Connect the main USB cable of the monitor into the back USB port of the PC.
1helpful
USB outlets
I'm assuming you are speaking of the USB ports on the Monitor?
Do you have the USB cable running from the back of your computer to the back of your monitor? For those ports to work, you need a USB cable that runs from the computer to your monitor. This is a cable in addition to the power cable and the video cable. Verify you have three cables connected.
If you are not speaking about the USB ports on the monitor, please advise...
1helpful
Monitor usb
There should be a USB cable from one of the usb ports on your computer to a small square (upstream) USB port on the back of your monitor. This will activate the four (downstream) usb ports on your monitor.
Good luck...and I hope this is helpful!!
Mitsubishi Diamond Pro 900U 19" CRT Monitor Logo
Top Mitsubishi Computers & Internet Experts
Kevin Nelson
john h
Are you a Mitsubishi Computer and Internet Expert? Answer questions, earn points and help others
