ZTE Warp Logo
Anonymous Posted on Aug 15, 2017
Half of the screen on the ZTE Warp has gone Dark. There's approximately a half inch strip on the left side that stays dark. If the phone is flipped, the screen image flipps accordingly but the black strip would then be on the right. So that dark strip of screen stays dark. I don't know what to do. Is there an update needed or is it not software but hardware related? Thanks in advance!
3 Related Answers
Anonymous
  • 268 Answers
  • Posted on Jan 18, 2012
SOURCE: Can't receive calls on my ZTE warp
somthing wrong with your settings.
restart your cellphone,
Anonymous
  • 32281 Answers
  • Posted on Feb 10, 2012
SOURCE: What's your problem?i got a problem with the battery of my zte warp..how can i keep it charged at less one day?..it takes 2 hour to stay uncharged
If the cell phone battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% and graduallythe charge reduces until the battery won't charge up at all. OR The batteryshows a 100% charge but when the adapter is disconnected the battery drops offto zero capacity in a very short time. If the battery drops to an unacceptablecharge level then the battery needs to be replaced.
Anonymous
  • 10 Answers
  • Posted on Oct 22, 2012
SOURCE: zte warp got wet
When this happens, immediately remove the battery. Let the phone dry (it may take several hours) before you put the battery back in and try to turn it on. If it is only water, and you act quickly enough, your phone may be okay.
1helpful
2answers
LG tv 55uh6150 half the screen is dark and the other half is fine would replacing the led strips fix the issue?
This is an edge lit set and they are known for failure and having dark parts on the screen, it's something you can do yourself but it takes a few hrs to change them, search some videos on changing side lit lamps as these are different than sets with lamp strips. Good luck
VIZIO M701D-A3R SCREEN GHOSTED WENT DARK OVER HALF
Aberrations of picture on these sets can usually be traced to a problem with the t con board.
2answers
My zte wont turn on all the way
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Nov 02, 2012 • ZTE Warp
Display half of screen
screen back light on the other side is busted which need replacement.
Vizio lcd flatpanel tv with dark background
If half screen is affected it will be either a board (LCD and Plasma have different names) but in those one board drives each side of the screen unit--worst case is the display panel itself which is fatal from a cost point of view.
When turning the TV on, the left half side of the screen is dark and bleared, while the other side is normal stays like this for a while, then it is gone and it appears for about half an hour.
I have had the same problem for a couple of Months . Bought my lg in March 2009, just had it diagnosed as the Screen . Apparently they are not Lg screens but a version called AUO optrix . my tv is a non economical repair and i am waiting for Currys to get back to me . let me know if i can be of any help. Mike
Right half of the screen mostly green and red with vertical strip
It sound like there is a problem with the mainboard. What is the model number of the TV?
Top ZTE Cell Phones Experts
vince
nexrad_chris
Paul Carew
Are you a ZTE Cell Phone Expert? Answer questions, earn points and help others
