Question about Hitachi 42HDT79 42 in. Plasma Television
42hdt79 Hitachi TV will not power up. Cord is good TV is dead ??
TV turned itself off and is completely dead. Nothing can make it come back on. Is there a fuse that blew?
Posted by lennyplucins on
  • lennyplucins Apr 07, 2009
    The main power button is on the bottom toward the middle. There is no other buttons for power, except the right side. Thanks anyway
  • BOB  BROWER
    BOB BROWER May 11, 2010
    well there are 3 fusess in there . but unless you had a lighting strike or powwer flashed and spiked if the fuse blew there was a good reason and replaceing the fusess will just make them blow again ..... and the more and more you shock that power supply the more damage you do to your set .... plasma tv sets are hard to fix for us guys that do it all the time , if you dont have the tools and the know how dont mess with it you will just make the problem worse $$$$$$$$
Anonymous
Try the button on the front bottom, under the power button on the front.
Posted on Apr 07, 2009
Tv blue light comes on but no picture
power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
I hope this will help in solving the problem...
Jun 30, 2011 | Hitachi 42HDT79 42 in. Plasma Television
My Hitachi tv model p42h401a will not turn on. The "standby"light is not on either. I have checked the power supply and that is working.
Have you opened the actual TV and checked the power supply board inside? Because that is what it is. You need a new one.
May 09, 2011 | Hitachi 42HDT79 42 in. Plasma Television
I have a hitachi 42hdt79 and yesterday the power just went off. the power button on the tv does not power it on nor does the remote. just dead.
The internal fuse, if you are lucky, may have gone. It is situated before the on off switch and mains filtering circuit board.
Jan 01, 2011 | Hitachi 42HDT79 42 in. Plasma Television
Hitachi Plasma TV 55HDT79 that is turning on and off and back on
Go Setup in the menu. At the bottom you will see Reset The Software when power is turned off. Switch this to No.
Apr 21, 2010 | Hitachi 55HDS69 55 in. Plasma Television
Hitachi 42PD7200 Plasma TV gone dead
this problem is from smps power supply of your tv circuit, may be power capacitor may be short , power transister may be short pls check some spair of power supply
Apr 06, 2010 | Hitachi 42HDT79 42 in. Plasma Television
I have a hitachi p50x01au plasma and I was just watching tv and it turned off by itself.I tried to turn it back on and all I get is a green blinking light.Do I need to call a technician?
you need to unplug power cord from back of tv and let it set for awhile then plug back into the back of the tv i also have a plasma and it sometimes does that also
Jan 06, 2010 | Hitachi 42HDT79 42 in. Plasma Television
Tv not turn on
Ur power board is dead.need a new one.
Sep 20, 2009 | Hitachi 50SBX78B 50" Rear Projection...
Audio quality
I fixed it by turning the main power switch off for thirty seconds and then turning it back on.
Mar 03, 2008 | Hitachi 42HDT79 42 in. Plasma Television
No power
I am working on one with the same problem, there is a hidden power button on the underside of the tv, just below the normal power button on the front. Make sure you didn't hit this button. It must be a vacation power button. This button blends in with the case, but it is square button
Nov 11, 2007 | Hitachi 42HDT79 42 in. Plasma Television
Hitachi 42HDT79 42 in. Plasma Television Logo
453 people viewed this question
Top Hitachi Televison & Video Experts
matt martin
matt martin
Todd Hill
Todd Hill
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
