Durabrand DB1200 CD Player Logo
A
Anonymous Posted on Aug 11, 2013
Duraband 1215 am fm cd receiver plays, but get no am fm reception, even with a new antenna
Coaxial FM antenna
Radio Shack has an
adapter catalog number 278-0291. It takes some effort to push the 278-0291
adapter onto the FM UNBL 75 ohm terminal so wait until you have the 278-0291
installed before you connect your 75 ohm coax on to your new adapter.
This will resolve your FM screw on F connector antenna interface issue.
I see others trying to
help suggest using a 300 ohm to 75 ohm transformer match unit, this isn't what is needed. Your receiver antenna input IS a 75
ohm input.
Very poor FM receptio, and virtually no AM reception
The cascadia has an integrated AM-FM-WX, XM?, and CB antenna system, that is also prone to poor grounding. The best solution is to install aftermarket antenna systems for all of the equipment... I am driving a 2013 Cascadia with quite poor FM, and non existant AM, and WX reception. The XM works. I am afraid to hook up my CB to this, as it is pushing too much power, and is a sideband unit. I would like to hang the engineer by his/her toenails from the nearest tree for comming up with this garbage...
1helpful
FM antenna is not providing reception, despite cable connected to powered antenna amplifier. TV also connected to powered antenna amplifier (splitter) works fine. FM mode produces only static. I purchased...
If I understand your setup, you've connected the receiver antenna terminal to the output of the antenna amplifier. If this is true, I'd suggest trying the receiver using a plain old FM dipole antenna (available at Radio Shack and other stores) or even just a piece of wire hooked to the antenna terminal. You should be able to pick up some local FM stations then.
What might be happening is that the FM is being filtered out by the amplifier. Some amps made mainly as a TV signal booster have an FM trap designed to block the FM broadcast band. In the analog broadcast days, the FM band was right near the sound part of a TV signal, and the trap was there to prevent interference. It may be filtering out your FM band.It may also be possible that you're just overloading the FM antenna input with the amplified signal. Sometimes a signal can be too strong. Using a simple wire antenna will let you test the receiver by itself.
Other than connecting an antenna you shouldn't have to do any setup for FM reception. If you still get no stations at all when using a simple antenna, then the receiver may need service. But I doubt Circuit City would have sold a floor model that was defective, even at the very end, unless it was clearly marked as such and sold "as-is". I'm pretty sure you'll find that the receiver works with an antenna made for FM.
1helpful
The AM reception problem: It acts like I have no antenna. When I switch from FM (which works great!) to AM, there is no volumn. So, I turn up the volumn. As I drive along, the reception ebbs and flows,...
The FM antenna is not the same as the AM antenna. The FM antenna is what sticks out of the car. The AM antenna is inside the radio, a grayish black rectangular or round bar of metal, with wire wond around it on one end. Receiver sensitivity for an AM tune circuit is critical. If tuned properly, the reception should improve. However, they are not in most cases because of the additional cost to perform a good job and the expensive of more critical components.
Impossible reception radio AM FM. CD play ok. this equipment is new
did you make sure your antenna is connected? if so, you may have a bad antenna.
Improve reception
HI there,
Well Yes you can improve the reception, please follow the below steps -
Improve FM Radio Reception -
1. If you don't have an antenna connected to your FM receiver, purchase a simple dipole antenna--a simple T-shape flexible wire-- and connect it to the FM antenna inputs on the receiver. Because FM signals are directional, you'll want to experiment with the positioning of the wire to find the best reception of the station you're trying to receive.
2. If you're still not getting a good signal, try an indoor amplified antenna, which you'll find at an electronics store. Don't buy one unless you get a guarantee that you can return it for full credit if it doesn't solve your reception problems.
3. If your signal is weak because you live a long way from the transmitter, install an outside antenna and mount it as high as is practical. If you're primarily interested in getting signals from one station or from a group of stations in one direction, get a directional antenna and point it toward the transmitters.
4. If you're using a portable FM radio where the only antenna is the power cord, stretch the cord as straight as possible and experiment with positioning again.
5. Temporarily switch to monaural mode to improve a weak signal on an FM receiver.
Improve AM Reception -
1. Gradually rotate the radio 360 degrees. Leave it in the position where it sounds best.
2. Reverse the AC plug if it isn't polarized. (If you can flip the plug over, then it's non-polarized.)
3. Plug the radio into a different AC outlet.
4. Move the radio closer to a window.
5. Experiment to learn if appliances and powered products in your home are causing interference: computer monitor, television, electric blanket, light dimmer, fluorescent light, hair dryer, air conditioner, smoke detector. If possible, turn off the offending item. Otherwise, move the radio to another room.
6. Upgrade to an external antenna if your receiver, tuner or radio has a place to connect one.
7. Buy a passive AM antenna that doesn't need to be connected to a radio or receiver.
Good Luck!!
Thanks
2answers
JVC detachable face with auxillary input
You may have a bad antenna or antenna cable.
FM signals are measured in microvolts and are easily influenced by poor antennas or a mashed antenna cable.
Onkyo receiver playing in mono only
sounds like a reception problem. Is there a visual meter for the reception? Check your antenna.
3answers
FM RADIO DONT WORK..MODERATE AM
hi sounds like a torn ant wire or bad ant change the ANT with all the length wire till the reciver make sure a good connection in the reciver good luck
Top Durabrand Car Audio & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
 Grubhead
Grubhead
Are you a Durabrand Car Audio and Video Expert? Answer questions, earn points and help others
