2000 Ford Focus Logo
Posted on Apr 05, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Need size of battery for 2000 ford focus
What size of battery do i need for a 2000 ford focus? Is it necessary to use a special tool for the battery when disconnecting and reconnecting the battery?
wolfman21955
Level 2:
Habit-Forming:
  • Expert 97 Answers
  • Posted on Apr 06, 2009
wolfman21955
Expert
Level 2:
Habit-Forming:
Answers
97
Questions
0
Helped
38974
Points
217
Dependant on engine size and fuel type, any size from a 390 amp battery, if it is diesel then a 590 amp battery. No special tools needed, only a small ring spanner. Make sure yyou disconnect the earth lead first. Also you will need to enter the radio code after changing batteries
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 03, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1761
Points
Length 315mm
Width 175mm
Height 175mm
OR
Length 278mm
Width 175mm
Height 175mm
  • Anonymous Jan 03, 2013
    it's for diesel Ford focus 2000 year, i think model is from 1998 - 2000 ? and Cold Cranking Amps from 580 if you live in a country, which temp reaches -30C (sometimes) try Cold Cranking Amps over 680 and more
1helpful
Can't see the marks on the camgears what do I do Ford focus 2000 Dohc help
The 2000 Ford Focus has the Zetec engine, I believe. On the Zetec, the camshaft timing using notches carved out of the REAR end of the camshafts. With the valve cover off, you would need a special tool(we use a metal piece similar to the shape and size of a measuring ruler we all used in k-12 school) to insert into both camshaft rear notches to line up the timing. Other than that just make sure the crank is lined up. Presto!
Note: There are 2 ways those notches can line up, there's "right side up" and "upside down" ... The special tool should ONLY fit into the notches when they are right side up. The thickness of the tool would need to be about 2-3mm(I think).
2helpful
2answers
How can I set timing of a Ford focus if I can't see the marks on the camgear
take number 1spark plug out and put number one piston at top dead center of the chamber that's will be your timing make sure to mark the harmonic balance r
2answers
Replace broken timingbelt
What engine does yours have ? 2.0l Zetec ? You need special tools !
1helpful
2answers
How do you replace shocks on a 2005 ford focus
the focus has struts, no shocks, use need special tools to replace struts
3helpful
Ford focus' wheel bearings (2000 lx)
is difficult you need a press and some special tools as torquemeter to set the nuts to avoid the worn out of the new bearings.try to a local garage.buy the parts by yourself and the cost isnt so high!
1helpful
Timing marks for 2000 ford focus? can you time the engine with out the special tool? its a dual overhead cam
Click on the following direct Link.
With the DOHC you will need the Camshaft Sprocket Holding Tool and Camshaft Alignment Tool.
Let me know if this helped, or if you have additional information or questions. Feel Free to contact me at FixYa.com!
http://www.2carpros.com/car_repair_information/year/2000/make/ford/model/focus/2000_ford_focus_timing_belt_diagram_marks.htm
2helpful
2answers
2002 ford focus. need to know where timing marks are to set it.
there are no marks, special tools are needed when replacing the timing belt.
1helpful
How do i take out fuel injector ford focus tdci 2000
Special tool required, see a good auto part store for the tool
11helpful
5answers
2000 ford focus twin cam timing
please helpme i need timing marks for ford focus 2000 16 valvs
Top Ford Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
xxxxxx xxx
Are you a Ford Expert? Answer questions, earn points and help others
