Question about Watts Onan Portable Generator - 4000 , Model# 5500
VALSI 5,500 WATT GENERATOR WILL NOT START
I have fresh gas and oil and followed the exact instructions in
startinf the unit and will not start,I bought my unit 2 and half years
ago and it was used only once for a fews days due to hurricane.any ideas?
Posted by markcassi46 on
boeing46
    Problem Solver:
  • 7 Answers
All generators need to be run once a month. All things from the tank to the and including the carb will get gummed up with dried out fuel. I have a whole house generator and a 5500 watt gen set on my motor home. I keep fresh fuel in the stand alone house generator in California in case of a bad earthquake. I drain the gas after every run and keep all vehicles full of fuel just in case. Run gen sets at least once a month or pay pay pay!!
Posted on Jun 13, 2009
Anonymous
  • 116 Answers
If it was sitting with old gas in carb you may need to clean hte bowl and jet. probably gummed up.
Posted on Apr 17, 2009
I have a Craftsman 2-cycle blower/vac and its only 3 years old and have changed out the spark plug and fresh mixed gas and still won't start. I need some help anyone know?
Check age of gas. Cannot be more than 30 days old. Make sure to use fresh gas w/synthetic 2-cycle oil @ 40:1 ratio (1 gal.) Gas to 3.2 oz. Oil). Do not use old or stale oil/gas mixture. Always use the proper oil/gas mix. If you do not, your engine will suffer rapid, permanent damage. May need to clean or replace carburetor.
Sep 18, 2011 | Craftsman Garden
I have a canon lawmower which is a two stroke engine and it is at least 20 years old so i have unfortunatley lost the manual over the years. It has recently ran out of oil so i have bought some more but it...
Serena you are all wet, literally. You mix oil and gas, not oil and water as they do not mix and will cause total failure of the engine.
You can buy little bottles of 2-stroke oil at auto parts stores and wal-mart and they will have written instructions right on the bottle as to how much gas to add to them. Generally one little bottle to 2 gallons or so of gas it is not critical, especially on a 20 year old engine. I use the same premix on chainsaws, hedge-trimmers, weed-eaters, etc.
Jul 07, 2011 | Garden
Husqvarna 455 Rancher loses power, have tried the following: fresh premium gas with ams oil 2 cycle oil, new plug, cleaned air filter, runs for a little while but starts stalling out after using about a...
check your fuel filter/gas line in tank you could have a crack in your line that in the fuel till it gets below half tank then sucks air through crack, It's a possibility, other than that, check your exhaust port, but sounds like a fuel problem check your fuel tank vent also to make sure it is venting. Good Luck
May 03, 2011 | Husqvarna Garden
I have only used my saw a handful of times and it has always done this since i bought it new at lowes. It wont lube the chain with oil and gets vry hot at the clutch it will go through a tank of gas to a...
I have the exact same saw. I bought it new 6 months ago also from lowes. It has the exact Same problems you are describing. It does not appear to be oiling the chain enough, the Chain is visibly dry,very hot , and dulls quickly. It uses a half tank of oil to a tank of gas. I am Also in search of an answer.
Oct 20, 2010 | Husqvarna 350 18 Inch Gas Chainsaw 52CC...
Wht is the gas to oil ratio for a homelite vac
Yours is not a current model and I did not find a manual. The following is an excerpt from a 26cc MightyLite Blower/Vac UT08550/UT08951 "Operator's Manual":
This product is powered by a 2-cycle engine and requires pre-mixing gasoline and 2-cycle lubricant. Pre-mix unleaded gasoline and 2-cycle engine lubricant in a clean 1 gallon container approved for gasoline.
Recommended fuel: This engine is certified to operate on unleaded gasoline intended for automotive use.
Mix Homelite Premium Exact Mix lubricant with gasoline according to the instructions on the package. If Premium Exact Mix lubricant is not available, use a high quality synthetic 2-cycle engine lubricant, mixed at 2.6 oz. per gallon (US).
Do not use automotive lubricant or 2-cycle outboard lubricant.
NOTE: Premium Exact Mix fuel mix will stay fresh up to 30 days. DO NOT mix quantities larger than usable in a 30 day period.
PREMIUM EXACT MIX (50:1)
GasolineLubricant
1 gallon (US) 2.6 oz.
1 Liter 20 cc (20 ml)
1 quart fuel:3/4 ounces of oil = 1 Gallon fuel:3 ounces of oil or slightly less than 43:1. Not what a current manual recommends.
If properly adjusted your blower will operate fine on 50:1 regardless of what the manual reads. HTH
Lou
Jan 31, 2010 | Homelite Leaf Vac Attack
Need to know gas mixture
GasolineLubricant
If properly adjusted your blower will operate fine on 50:1 regardles of what the manual reads. HTH
Lou
Jan 29, 2010 | Homelite Consumer Products Backpack...
Bought a 2002 Rm125 about 2 months ago, with a fresh top end....First ride was great with impressive power throughout. About two weeks later I noticed that it was missing some about half throttle , and...
My first thought is low compression... which leads to a few questions...
What fuel to oil ratio have you used?
What do you mean by 'fresh top end'? To me a fresh top end includes piston and rings and cylinder bore, gaskets and crank seals. Anything less on a 2-stroke is an incomplete job and usually leads to premature failure.
Have you followed break-in procedure on your fresh top end? Double check the head bolt torque.
Do a compression check first then go from there.
Dec 28, 2009 | Suzuki RM 125 Motorcycles
I bought a 1997 jeep grand cherokee 2 years ago. Because of deployments to Iraq and Afghanistan, this vehicle has been in storage for all that time. Should I have all the fluids (oil and gas) replaced...
if the vehicle was not started for 2 years, the engine may be stucked up. if it is not, the replacing the oil is ok. since 2 years is a long time you have to check everything.
Sep 10, 2009 | 1997 Jeep Grand Cherokee
Toro Model # 20331 Starts, but doesn't run
Mr. Fixit...excellent advisement...really appreciate it. It got my grass cut today. Big yard! Problem is, when I finished, now I have the same problem with it not running...what do you think: take the Toro to the junk yard or what? Thanks!
Apr 25, 2009 | Toro Lawn Mower With Toro Power Tools
Chain saw starts with starting fluid only but will not run.
Hi lwhssh:
Suggest you drain the fresh gas/oil and add a fresh batch but first add a gas stabilizer to your batch of gas/oil in the storage container. You will probably still need to use starting fluid for a few times When 2 cycle engines sit for a long period of time, the gas/oil mixture undergoes a change and tends to leave a residue on the delicate parts of the carb. The gas stabilizer will help that.
I always do the following for 2 cycle engines when I put them up for the winter. Empty the gas container on the device and then start it to use up any gas left in the fuel lines and carb. this keeps any residue from forming.
Hope this helps Good luck Loringh PS please leave a rating if appropriate. Thanks
Nov 28, 2008 | Garden
Watts Onan Portable Generator - 4000 , Model# 5500 Logo
1,452 people viewed this question
Top Watts Electrical Supplies Experts
rlev_7
Level 1 Expert
Muntejaya Ginting
Muntejaya Ginting
Are you a Watts Electrical Supply Expert? Answer questions, earn points and help others
