Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive Logo
Posted on Apr 05, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Need a power cable
How many volts for a seagate free agent 700
Anonymous
Level 2:
Sniper:
  • Expert 86 Answers
  • Posted on Apr 19, 2009
Anonymous
Expert
Level 2:
Sniper:
Answers
86
Questions
0
Helped
44529
Points
261
A user on the Seagate forums indicates that his uses a 12V 2A DC power supply. I would suggest, however, that you remove the hard drive from that enclosure and place the drive either inside your PC or inside another enclosure.
If all else fails, contact Seagate: 1-800-SEAGATE
Let me know if this helps!
Transplanting Hard drive from Seagate Free Agent go flex to another enclosure. I believe the power supply is dead only one light comes on and it just beeps
Here's one case. They're not terribly scarce, but not found just everywhere, either.
http://www.amazon.com/Aluminum-External-Drive-Enclosure-Silver/dp/B000F3WB0Y
I received this message about Seagate Free Agent Go 500 Gb: Cannot find the specified file. Make sure you specify the correct path and filename.
It seems that your Seagate Free agent has lost it connection to your laptop because of the problem in usb cable
Try to unplug the usb cable from your laptop and plug in again
Seagate free agent 1.5 terabyte will not stay connected to my computer When I connect my free agent to my computer (Asus laptop with Vista Home premium) all the folders show up and I can access files for...
Check the HDD on a different USB port. It there is still problem, try that with a different computer. If it still shows this issue, try changing the USB cable. If the issue persist, its your HDD.
2answers
Installation issue - Not recognizing
hmm, no problem plugging in either side, just be sure to do the power cable first. What's doing the beep, beep?
Found a guy who had similar prob, here was his solution:
Go to Control Panel. Click on Device Manager.
Check to see if FreeAgent is shown as a disk drive.
If not, check the device list for any Free Agent device, double click and check driver. No driver installed? Update does not work? On the driver tab….click uninstall device.
Shut down computer. Unplug Free agent USB and power at the drive.
Reboot computer. As it is rebooting, plug in the power cord. Wait a minute or two….then plug in USB cord.
Windows will “found new device” ….. Just let the computer complete the reboot.
Then go to the device manager. Chances are you will find Free Agent in the drives….and in the USB list of devices. Open windows explorer….and you should see you Free Agent as a drive.
Windows will ask you to install manufacturer disk. You have no disk…non needed. Windows has installed the device. Just click on close. I you keep getting windows wants to install device…..ignore it. You can click on “don’t ask again”. (That is if your Free Agent drive is showing in the device manager as a disk…and in windows explorer….along with your other drive or drives.)
If at some later time….your Free Agent drive does not appear….repeat the steps as listed above.
(You may think it is not working….or that it has gone bad. Try this before you try to return.)
Seagate Tools…the new version….does not recognize to diagnose the Free Agent….
I have not tried Seagate Tools after getting the computer to recognize the drive.
I am surprised Seagate does not provide a Tool to recognize their own drives…and install and/or test Free Agent.
This does work for me with Vista. Thought I had lost the drive…. Seagate should provide a patch or a drive that Windows will recognize when you get the “found new hardware” and Windows asks you to insert manufacturer’s installation disk. I do not understand why that is not already there….a driver file for Free Agent...that Windows would install.
I did not buy Pro….because I did not need the backup software. I wonder if those who bought Pro are having these problems.
Win 98
You would need two set of driver:
  • motherboard USB drivers;
  • mass storage driver from Seagate for Win98.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
2helpful
4answers
Help for Seagate Free Agent 500 GB external hard drive
465.66 x 1024 x 1024 x 1024 = 499,998,617,764 bytes. The problem is the definition of gigabytes.
4answers
Power problem
just reading this forum I think I have bought a total POS. Damn! wich i would have read this first. This boat anchor has all of my backup on it, is only a month old and is now junk. What is this the 3rd world's way of collecting all of our data when we return them?
Top Seagate Computers & Internet Experts
Sean Wright
Sean Wright
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
