SOURCE: I have a Magic Chef beverage cooler, MCBC580DBT,
same problem w mine and yes if you take the cover off the inside display you will be able to remove the board mine has a hole burnt in it.unplug harness w red blue and brown wires and jump and jump from brown to red unit will turn on you need a new board
There a couple of power supplies that run the fan, and you probably have a bad power supply, that needs replace or repair, try changing out the lectronlytics caps on the power supply modules .
