Question about Integra DTR-8.3 Receiver
SOURCE: Low to no volume output from Integra DTR-5.2 receiver
most higher end integra's have a input level adjusment or input selection for each and every input. Perhaps you are not on the correct input, go to onscreen programming and check out the input level and input select - also try the tape in another input like tape 2 or cd. It will not hurt the receiver for a test. Also, if you are using the cheap cables from the manufacturer - try a pair of cables that you know work or go by some. BTW, you don't need to spend $40 for cables order them online through amazon or other store. Gold / sliver plated oxygen free are best.
Posted on Jun 30, 2009
SOURCE: my left rear speaker has no sound. All others
Swap your left and right rear speaker over. If you still get no sound from the right speaker connected to the left speaker connection on the receiver, then you have a fault on the receiver output. Check your manual first to see if any setting switch off the rear speaker before taking the unit for repair or replace
Posted on Nov 26, 2009
SOURCE: I have an integra dtr 7.7 receiver which when
obviously a short somewhere in the system....
you know what i would do?
pray to god you are still under warranty! XD
its a beautiful machine....
Posted on Jan 08, 2010
SOURCE: Hi we have an Integra
Does this normally happen if you press a few buttons or settings faster in succession? If so then maybe the receiver can't keep up with multitasking or what you would call processing power so maybe just try to not select functions as fast and give it a few seconds in between changing settings before switching to another. my cellphone and receiver will also do this because of lower quality components used in manufacturing. A lot of company's now days to compete with price points are cutting corners so certain components are lacking to keep up with demand of other components in the system.
Posted on Jan 06, 2011
SOURCE: my integra dtr-40.2 reciever will
Please unplug the unit from the outlet for 15 mins and then check if the symptoms still there.
Reset the unit to factory setting by following the steps below.
> Power on the unit.
> Press VCR/DVR button key + On/standby key at the same time to re-initialized the memory to factory settings.
Check also if the remote control is working fine. Aim the sensor of the remote control directly to your cellphone camera, while pressing any button key from the remote control (button key with an issue) you will be able to see the flash of an infrared emitted by the remote control indicating that it is working fine. Watch the video below for more info.
Jdvillanueva
Posted on Sep 13, 2011
Sep 18, 2016 | 2004 GMC Envoy
Aug 24, 2013 | Integra DTR 5.6 Multi Media Amp
Jun 02, 2012 | Apex Digital AT1314DV 13 in. TV/DVD Combo
Aug 03, 2011 | Ford F-150 Cars & Trucks
To reset the AV receiver to its factory defaults, turn it on and, while holding down the [Video 1] button, press the [Standby/On] button. "Clear" will appear on the display and the AV receiver will enter Standby mode.
Dec 26, 2010 | Audio Players & Recorders
Mar 18, 2010 | Lands Phones
Jul 29, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
Jul 28, 2009 | Samsung RS2578BB Side by Side Refrigerator
Jul 03, 2007 | GE 24GP653 24" TV
44 people viewed this question
