Hello Robert, I am happy to assist you. Let's try resetting the microwave by either unplugging it or flipping the household circuit breaker to the off position. It is important to wait approximately ten minutes and then turn the unit on. If the issue persists, then based on the symptoms you are describing, it could possibly a faulty fuse or the main control board. If the instructions above do not solve the problem, I am fairly confident that an authorized service agent will be able to restore your appliance to its normal operating condition. You can often locate a qualified service technician on the manufacturer website.
SOURCE: Frigidaire over the oven micro
The magnetron will have overheated and will need to be replaced. Also, there is a thermal cutout mounted on or near the magnetron. It will need to be replaced, too. You can find exploded views and order parts here: http://tinyurl.com/gv383 What you'll need are the parts marked as reference numbers F73 & F74 (73 & 74) on diagram number 6. You might also be able to find cheaper substitute parts at a local applaince parts store. You can find critical safety and disassemby tips at our site via our FixYa listing: http://tinyurl.com/yzjozk
SOURCE: microwave frigidaire model GLMV168 will run but
Not what you want to hear but the voltages in there are seriously high. Normally the Capacitor and diode are faulty due to dirt build up and very possible the magnatron is als the culprit. One needs to have some good testing equiptment to source the problem. If you insist on doing the repair, buy the magnatron plus capacitor plus HVdiode and install as you remove the faulty components.(do not make a mistake with the wiring)
