Need code for Electron Tv
I have a new Electron Tv and my all for one remote will not work, i have searched the internet but with no luck for a code.....can anyone help me?
Posted by tammy_l_c29 on
  • 6 more comments
  • mikev01 Apr 06, 2009
    I have several remotes and can't find a code to work on any of them.
  • jangnat Apr 11, 2009
    Just bought a new Electron LCDTV and the universal remote for the cable TV will turn on the cable okay but not the power on the TV. I have to use the remote that came with the TV to turn it one & then use the other remote to turn the cable on, which is a real pain.
  • Anonymous Apr 24, 2009
    Same problem here, been searching all over. Anyone have any luck yet? I also went through the entire Rogers cable universal remote codes (by using the feature to scroll through each one).
  • tammy_l_c29 May 06, 2010
    Hi Candlegirl....I am using a Bell Express Vu remote right now and still no luck, we have tried several types of all in 1 and none of them worked either. Not wasting anymore money on remotes I will just get up and turn volume manually,lol.
  • robwindude
    robwindude Jan 18, 2012
    Try 094 or 0094 depending on the number of digits you need to enter.
  • maryjeanmcdo
    maryjeanmcdo Aug 06, 2012
    me too none of the solutions work so far i have a philips universal
  • Joseph Ducey
    Joseph Ducey Jan 06, 2013
    where is the electron tv remote numbers
  • Carole Sep 16, 2013
    I just called Curtis and was told they can send me an original remote control for my 37 LCD Electron Tv in the original package for $15.00 and that includes shipping. I am hesitant to give them my credit card cause I find this a little too cheap for this remote
Anonymous
I was having the same problem but I finally got my universal remote to locate a code 1548
try that ? worked for me
Thanks
Tammy
Posted on Jun 07, 2009
  • d s Oct 05, 2010
    hey what kind of universal remote did u use so i can get the same kind pls
  • s8n1st
    s8n1st Jan 31, 2011
    I used an Atlas DVR 1055 that was provided by cogeco,
Anonymous
    New Friend:
Have and electron tv. The Shaw remote will do all but the sound. Any ideas? thanks
Posted on Dec 19, 2009
paboot
    New Friend:
Just tried the code Tammy said 1548. I works great.
Posted on Jan 02, 2010
Anonymous
I have an electron tv and a shaw universal remote can anyone help me!!!
Posted on Aug 06, 2009
taxilady2002
    New Friend:
I found a number you can call for replacement electron remote 1-800- 968-9853
Posted on Feb 28, 2011
  • 1 more comment
    I called them for a replacement remote for my LCD 37" Electron TV. They to,LCD me they could order an original in the box for that model for $15' and that included shipping ! I can't go to the store and buy one for that price. She said it was not a universal remote, but the original ? I'm reluctant because it sounds too cheap.
    Has anyone had any dealings with this company ?
  • Edward Russell
    Edward Russell Apr 10, 2018
    Is there a code for electron tv for my shawdirect remote?
Anonymous
I just read somewhere that Electron TV's are manufactured by Curtice. Check the model number, but make the brand "Curtis" and see if that works.
Posted on May 08, 2009
Rod Peever
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 4 Answers
2352 under curtis works for my electron model #lcd3216e
Posted on Dec 01, 2011
Anonymous
    New Friend:
Hi: I have a Mororola DSR 505 Shaw Star choice recevier and an Electron 37" TV. I got the Shaw remote to work by scrolling through the numbers one by one using the directions provided with the remote. To do this press enter then mute and hold until the lights flash then press the up button (above enter) once the lights will stop flashing and then in 2 seconds they will start flashing again. Keep pressing up every 3 seconds (when the lights start flashing again) until the TV turns off then press mute if the TV turns on press enter and you are done if not then press the down button to see if you went past the right number.
It took me about 25 minutes to find the right code, I hav know idea of the number but it should take about 5o minutes to scroll through 1000 numbers so it might be around 500?
Posted on Sep 01, 2010
djskillet
I was having the same problem until I tryed the learn from teacher remote command you have to program each button seperately but it will work the remote I used was a RCA universal remote with voice control the user number I don't remember but it was from the source and cost $50 canadian so if you can learn from a teacher remote this might work for you
Posted on Feb 14, 2012
robwindude
    New Friend:
0093
0094
1548
These are all the possible codes I looked up 0094 worked for me but these are listed or have worked for others.
Posted on Jan 19, 2012
Anonymous
    New Friend:
Cannot get the remote from cable box - Motorola to work with Electron tv... Thinking maybe I'll just get a new remote if 1548 works on one of them...should work with Motorola cable box too...lol!
What universal remote do you have Tammy?
Posted on May 06, 2010
What is code for universal RCA remote and Electron TV
0281,0294,0225. Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts.
http://electro-medical.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Search the site by type in the brand name to your device, in the "Search box at the top right of the display window" to see the set-up codes to your device, with different brand remote controls.
Sep 25, 2015 | RCA Televison & Video
Codetv sanyo telecommande universel electron ?
Your universal remote probably has a code search feature that allows you to seek a code that will control your Sanyo TV. If a search through all codes stored in the remote fails, you may have to try using another universal remote. All universal remotes do not have the same codes stored.
Dec 08, 2014 | Sanyo Televison & Video
I have Telus Optik TV with a Cisco remote and an Electron TV (32", not sure the model number) and I need a code to program my remote. Nothing in the Telus guide, autosearch not working. Anyone? Thanks
1012. This is the code to check with Electron TV. If you wish to get more, check these sites. http://remotesearch.blogspot.com/
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Sep 21, 2013 | Televison & Video
We have a LCD Electron TV recently purchased from Walmart and we are trying to find the code to program an RCA universal remote control to work with it, but we are having problems. We tried everything...
Visit the below link, it is a RCA remote code finder.
Enter your RCA remote model, the select TV, then search. This should help in getting the code...
Good luck.
Mar 09, 2011 | RCA Televison & Video
Who makes Electron TV sets I need to know what company builds Electon tv's so I can look up the code # for my remote
A lot of times with the off-brand TVs it's easier to use the remote's "code search" function (if it has one) than to try to find the actual code.
Some others have had luck with 1548. Have you tried that code on your remote? What kind of remote do you have? I've heard that Curtis makes the Electron TVs.
I hope that helps.
Dec 20, 2010 | Televison & Video
Still can't find a code for Electron LCDTV
You have joined the ranks of those who have several 'universal' remotes. They aren't. They are, at best, multidevice or multibrand remotes and even the 'learning' remotes don't learn from some originals. The use of the word 'universal' is a fraudulent nomenclature.
In looking at the product description, I noticed this:
"The DRC450 remote control is designed specifically to work with all Motorola and General Instrument Digital Cable Terminals."
It was then never designed to handle any updating.
You might try to obtain newer codes from the Motorola site for your model:
Motorola DRC-450
I didn't see any provisions for updating the code set via computer so it will likely never do what you want.
Jul 06, 2009 | Logitech Harmony 550 Remote Control
I need code for electron tv
Are you searching for code for a new universal remote control? My Toshiba TV did NOT come with a remote control, so I purchased one from a third-party vendor, but I didn't know what code to use to make the new remote control operate my other components (DVD, VCR, Stereo, etc.). I Googled the Toshiba website, went to the site's "Service" department and downloaded a copy of the TV's user manual. I found the code for the remote control in this user manual.
Good luck.
Jun 19, 2009 | Element Electronics FLX3220F 32 in. LCD TV
Universal code for a Electron TV
We need a universal remote code for all new flat screen tvs. The old universal remote controls don't work with most flat screens.
Jun 07, 2009 | Televison & Video
Need universal remote code for ge remote and Orion tv
The code that worked for me was 135.
Other Orion codes are 035, 121
Four digit codes for newer remote models might be one of the folling.
0236, 0179, 0463
Good Luck!
Feb 18, 2009 | Orion1934 19" TV
Code to enter on remote
i have new Sony BDP-S350 Blu-ray disc player. i want to connect it to E-net and some other devices, Camcoder, Pc, Laptop. i have got all HD ready cables,
I want to use the Universal Remote from my Sony Bravia LCD 42'' TV and Blu-Ray. can anyone help me?
thanks
omar
Dec 10, 2007 | Sony BDP-S300 Blu-Ray Disc Player
Televison & Video Logo
13,384 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
