SOURCE: Keys dont work.alternative way to change brightness?
Yes you can go into your display properties and look in the settings tab and look for advanced click that and open color tab or the overlay tab, color tab should get your brightness turned up, And if you can't see you can go into your bios and adjust your brightness from there and get it back to where you can see it if you can't write me back here so we can try another method. Ok I hope that helps you out somewhat, Oh yeah you can also hook up an external key board into your usb connections and you should be able to work everything from that too.
SOURCE: Acer Aspire 3103 Keyboard, pointer and usb unresponsive
it look like your motherboard have problem
SOURCE: Keyboard stuck in Fn mode
had the same prob on my laptop which doesn't have a seperate number pad so all I needed to do was to press "Num lock".
SOURCE: Dell Inspiron 6000 PC Notebook
you have gone into XP's backup and restore and reset your dell to a previous point right http://technet.microsoft.com/en-us/library/bb490854.aspx ?and if it was this way the first time you booted up it might have been installed wrong and it will need to be manualy serviced unfortunately most companies don't give restore disks any more, if your dell came from a retailer and it is still under 3 month the store should reinstall xp for you and if it isn't the store still might do it, dell might also offer a mail in fix for ya, if that doesn't work you can always go to best buy's geek squad and when you get it fixed make sure to make a backup disk using windows backup and restore, vista has software to use to make a back up disk i dont know about XP
geek squad or dell might haveto do that for you but it could cost you
Reboot the computer As the computer is booting repeatadly press the F8 key as the computer is booting
If done properly the user should get to a screen similar to the below screen.
Select the option for Safe mode command prompt only
Windows Advanced Options Menu
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice
select the safe mode option
then run your antivirus if still cant get rid of the virus restart again
Use the up and down arrow keys to move the highlight to your choice.
select safe mode with networking download anti malware and microsoft security essentials
http://www.microsoft.com/en-us/download/virus-malware.aspx?q=virus
anti virus and malware
http://windows.microsoft.com/en-US/windows/products/security-essentials
hope it helps
