Question about FUJIFILM Cameras
Want to take photoraphs but on recording mode all the time
Posted by alan richard bentham on
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • FUJIFILM Master
  • 102,366 Answers
What model Fujifilm camera?
Posted on Aug 11, 2013
I Have a Magnavox MWR10D6 DVD Recorder Certain shows or movies i try to record , I get a pop-up saying " Cannot record in +VR mode " . What is +vr mode and how do I change it?
VR mode or Video Recording mode is a feature on stand-alone consumer and computer DVD recorders that allows video recording and editing on a DVD rewritable disc.
In VR mode, users can create and rename titles for the scenes. Also, if a scene is deleted, the space allocated by it will be utilized later without the need of reformatting a disc.
If the user would like to record on the same disc again at a later time, in VR mode, users may eject the disc and it will not be finalized by the recorder until it is manually initiated. For the sake of comparison, any DVD disc recorded in VR's competitor V mode (or Video mode) will be automatically finalized before it is ejected by the recorder. Disc finalization is still required if the disc formatted for VR mode will be played in another DVD player.
Currently, users can only record in VR mode with the use of DVD-RW, DVD-RAM and DVD+RW discs, (updated in 2000 to accommodate DVD-R (General)) [DVD players marked “RW compatible” and “DVD Multi” can play DVD-VR recorded discs] and on some recorders, also on hard-disk drives.
Oct 29, 2009 | Philips Magnavox MWR10D6 DVD Recorder
What are the differences in the record modes? (HQ, SP, & LP)
The amount of recording time on a disc depends on the recording mode selected. The approximate recording time for each of these modes is listed below:
  • HQ (High Quality): Recordable time is up to 20 minutes.
  • SP (Standard Play): Recordable time is up to 30 minutes.
  • LP (Long Play): Recordable time is up to 60 minutes.
  • NOTE: If you record in LP mode, the quality of the scenes may be degraded, or scenes with quick movement may appear with a block noise when you play back the disc.
    Jul 08, 2009 | Sony Handycam DCR-DVD92 DVD Camcorder
    Limited recording time
    WS-100: 64 MB
    HQ mode: Approx. 4 hours 20 minutes
    SP mode: Approx. 8 hours 40 minutes
    LP mode: Approx. 27 hours 20 minutes
    You can go to the menu of the device and change the recording mode from HQ to SP to get longer recording time. Page 7 of the instructions explains how to change this.
    Mar 19, 2009 | Olympus WS-100 Digital Voice Recorder
    What is +vr and how do I remove it
    VR mode or Video Recording mode is a feature on stand-alone consumer and computer DVD recorders that allows video recording and editing on a DVD rewriteable disc.
    If the user would like to record on the same disc again in later time, on VR mode, users may eject the disc and it will not be finalized by the recorder until it is manually initiated. For the sake of comparison, any DVD disc recorded in VR's competitor V mode (or Video mode) will be automatically finalized before it is ejected by the recorder. Disc finalization is still required if the disc formatted for VR mode will be played in another DVD player.
    Blu-ray Disc and HD DVD also support VR mode-like features.
    Accordingly when DVD recorders became a viable option the features offered by <Video Mode> were minimal - the linear structure did not allow post recording editting or non-linear playback. Thus the DVD Forum devised Video Recording (VR) mode.
    Unlike DVD-Video this uses a much simplier file structure that allows non-linear modification to the recorded data. This means features such as partial erase, editting, playlists, simulataneous record/playback, mixing of different media types (JPEG, MPEG1/2/4, MP3, WMA, WMV etc) and, in future models, dual record are all possible."
    That basically summerises the differences: video is a linear recording that should end up DVD-Video compatible, VR is a digital recording mode that allows HDD-like functionality on disc.
    Do you need to always be able play your recorded DVD-RW discs on other DVD Players? If yes you have to use Video Mode, although some players will play VR mode discs, and you can test this easily by giving it a go.
    The main differences are:
    DVD Video mode on DVD-RW
    Plus points: Provides good compatibility (70% plus). That’s the only plus, plain and simple.
    Negative Points: Only simple linear editing possible, really just hiding a title. You can reuse space only when you delete the last title or completely reformat but lose everything in the process. No defect management. Requires finalisation to play in other DVD Players. No possibility of time-slip, i.e. recording and playing back at the same time.
    DVD VR mode (Video Recording)
    Plus points: Better use of recording rates by having intermediate resolutions. Defect management so reliable. Time-slip on 2 speed media if supported by the recorder, allowing record and playback at the same time. Non-linear editing. Any space freed is reused automatically (think hard-drive or Mini-Disc) and added to the remaining time.
    Negative Points: Not very compatible with existing DVD Players, plain and simple.
    Of course if you have a hard-drive based recorder then all the negatives are wiped out, as you use VR mode on the hard-drive which gives you all the pluses of VR mode, then record to DVD-RW in Video Mode to give you the compatibility to play the disc elsewhere.
    - A recording on DVD-RAM will always use VR mode
    - A recording on DVD-R will always use Video mode
    - A recording on DVD-RW can be either Video or VR depending which is set before the recording is made.
    - A recording to DVD+RW or DVD+R will always use Video mode
    - Many HDD/DVDR combi recorders will record to the HDD in VR mode and allow you to dub (digitally) to DVD-R in Video mode.
    Here is your manual:
    http://www.p4c.philips.com/files/d/dvdr3545v_37/dvdr3545v_37_dfu_aen.pdf
    Jan 10, 2009 | Philips DVDR3545V/37
    Skipping during the recording process
    "trying to record during playback"?... You can't record while playbacking in stereo mode, only in multitrack mode.
    Mar 08, 2008 | Zoom H4 Handy Recorder
    Zenith xbr411 DVD recorder
    See the manual, page 8:
    What are “Recording modes”? for DVD-RW
    There are two recording modes available using this
    recorder: VR mode and Video mode. When recording to
    a DVD-R disc, recordings are always in Video mode.
    DVD-RW discs can be formatted for VR mode recording
    or Video mode recording.
    VR mode recording
    • 4 different picture quality/recording time settings available
    (SP, LP, EP, XP)
    • Not playable on regular DVD players
    • Recordings can be extensively edited
    • Total number of titles on the disc should be less than
    99.
    (SP, LP, EP, XP)
    • Playable on regular DVD players (after finalizing)
    • Limited editing features
    99.
    Note :
    DVD-Video Format (Video mode) is a new format for
    recording on DVD-R/RW discs that was approved by
    the DVD Forum in 2000. You may therefore experience
    problems playing recordable DVD discs in some players.
    Symptoms include video artifacts, audio and/or
    video dropouts and playback suddenly stopping.
    Our company cannot take responsibility for problems
    playing discs recorded on this VCR/DVD Recorder in
    other players.
    May 24, 2007 | Zenith XBR411 DVD Recorder/VCR
    Should I use automatic or manual while recording?
    Select RCA camcorders feature both an Automatic and a Manual recording mode. Automatic recording places the camcorder into Auto Shot™ mode. Focus, exposure, iris control, white balance, and the video light are controlled by the camcorder during Automatic recording. This mode is particularly handy for those times when you want to be able to just point the camera and record. The Manual recording mode allows you to control many of the elements above yourself, as well as many of the camcorder's special features including Animation and Time Lapse. Manual mode is also where you access the menus and set the clock. Make sure you press in the LOCK button while setting the POWER switch to the desired setting, either "A" (Automatic) or "M" (Manual) record mode.
    Sep 06, 2005 | RCA CC-432 Camcorder
    How long can I record using a DVD-RAM disc?
    • Extra Fine mode (3-9Mbps record speed): Approx. 20 min. minimum per side. • Fine mode (6Mbps record speed): Approx. 30 min. per side (1 hour total). • Standard mode (3Mbps record speed): Approx. 1 hr. per side (2 hours total).
    Sep 05, 2005 | Hitachi DZ-GX20A DVD Camcorder
    Cameras Logo
    18 people viewed this question
    Top FUJIFILM Cameras Experts
    Muntejaya Ginting
    Muntejaya Ginting
    Falling star
    Are you a FUJIFILM Camera Expert? Answer questions, earn points and help others
