Question about Denon AVR-887
Denon AVR-887 turns itself off in 5 secs, any one know why?
Posted by jumroo on
  • jumroo Apr 05, 2009
    It was working fine for 3-4 hours during a party and then it stopped working. Now, it is disconnected with no inputs and outputs. just the power supply :-(
Dennis McCollum
  • 137 Answers
The postiver and negative reversed will not cause this problem if speakers or wires are shorted then yes. you may have either bad outpiy transistors or bad 15v regulator transistors,
Posted on Jul 21, 2016
Anonymous
You might have the polarities on the speakers crossed, check all speaker connections to make sure the pos and neg are connected correctly. If they are crossed, this will cause the receiver to short out, thanks
Posted on Apr 05, 2009
Does DENON AVR 887 support HDMI ARC? I bought the unit around 2007.
The Denon AVR-887 does not support ARC (audio return channel) on the HDMI output. You can find the specifications for the AVR-887 in the manual. ManualsLib has the manual here: https://www.manualslib.com/manual/38390/Denon-Avr-887.html . The specifications are listed here: https://www.manualslib.com/manual/38390/Denon-Avr-887.html?page=77#manual . The page with the monitor connection is https://www.manualslib.com/manual/38390/Denon-Avr-887.html?page=22#manual .
I hope this helps.
Sep 24, 2018 | Denon Audio Players & Recorders
Denon avr-887 code for comcast silver remote, red key. The 2 codes comcast gives me do not work. Any other codes known?
These are the codes that I have from a few extra sources. They are for ALL Denon receivers/tuners: (3 digit = 262,307)For the AVR all numbers consisting of a 4 number code, all begin with a "5". Here they are: 5006, 5048,5054,5085,5129, 5130, 5131, 5132, 5133, 5134, 5152, 5159, 5160, 5168.I was able to get my 529 rc to program some of the features but I will go back and try other codes that may have a better "fit" and operate more features. Hope this helps!
Sep 05, 2012 | Denon AVR-887
Where is the fuse in a denon AVR-887
It has to have one---follow the power cord inside the unit--if fuse is good consider taking it to a shop for an estimate.
Jun 17, 2012 | Denon AVR-887
Denon avr-1804 its turns back after 5 sec
Disconnect all speaker wires on back and then turn on. If it happens again, it's most likely a power supply problem. If it doesn't happen again, it was probably crossed speaker wires.
Dec 28, 2009 | Denon AVR-1804 Receiver
Left surround channel don't work
the problem you have seems to be on programing the master effects to get to it go to main menu and see the distribution and effects you want to hear on you home theather.remember that home surround needs some decoders to send the sound where the images come and its right built in....
Nov 17, 2008 | Denon AVR-887
Denon AVR 887 Upconversion With Wii
I have this hookup and it's working almost perfectly:
Wii --component--> Avr-887 --HDMI--> Sharp LCD TV
Sometimes the pictures don't show up during start up, but I figured it was (probably) due to Sharp's HDMI handshake issue, so I turned the TV off and then on, everything works.
Mar 20, 2008 | Denon AVR-887
Denon avr 887 input problem
Sell it on Ebay and buy a new 2309.
Mar 04, 2008 | Denon AVR-887
Flashing protector
Psgolfer ...I pretty shure you dont need that. It just needs to be reset, its in protect mode.....hold the power button down and the A n B speaker buttons down at the same time for 30 sec.....ok , Radricktip
Jan 01, 2008 | Denon AVR-887
Denon AVR-887 and Wii
I'm dealing with the very same frustration. Best I can tell, the problem with my setup is that this model (avr-887) can't pass component video input out through HDMI. Can anyone confirm that?
Prior to setting up the Wii, I'd only been using a single HDMI output from the denon to my tv/monitor.
The only solution I've found is to add a component video output to the monitor -- which is unfortunate. I'd much rather have only the single HDMI out.
Would love to hear if there is a way to set this up without having to add the additional component output...
Dec 26, 2007 | Denon AVR-887
My Denon AVR-887 Keeps turning itself off
I have one and the same thing happened. try resetting your microprocessor and if that does not work, then check the wiring of the speakers. if that is working fine and no wires are touching then I unplugged everything and was still having the issue. took it in for service and it was found that the transmitor was shorted as the speakers that I was using was too high in ohms. it is possible that it could be your caps also if resetting the microprocessor does not help. You can find out how to reset the microprocessor from your manual. If you have the Denon avr 887 with the system turned off hold the power on button and the speaker A and B at the same time for a few seconds. This is compatible to rebooting your computer. Hope this works for you as this was and is my husbands favorite past times.
Dec 01, 2007 | Denon AVR-887
Denon AVR-887 Logo
396 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
