DO NOT "POP" THE BACK OFF! You need a tool to unscrew the back. You may be able to find methods on YouTube to find out how to unscrew watch backs without proper tools. I'm not a watch repair professional but I do know that if you strip the threads you're gonna cause yourself more problems than solutions.
SOURCE: opening an elgin pocket watch
The best tool to do it is watchmakers knife, but any proper knife with hardened steel blade can do the job. Make sure the blade is NOT flexible.
Check carefully the sides of your watch and you will notice the groove. Place knife blade into that groove and press it in. At the same time try to make a scooping turn to lift the caseback. Usually there must be underlayed caseback as well and it opens exactly in the same manner.
Make sure you do all this carefully and do not let the blade to slip or your watch will end up with nasty scratches or even damaged movement.
That job isn't a big deal, but requires some skill, so, BE CAREFULL.
Don't forget to rate, please.
SOURCE: need a new crystal for Elgin 19703647
You do not need to go all over the world to find replacement for your watch glass. You have plenty of excellent watchmakers in France. I've been there, so, I know. All you have to do is to find your nearest watch repair shop and bring your watch in. Watchmaker will get all the measurements and will replace the glass.
Rate me, plz.
SOURCE: how do you open the back of an antique Elgin pocket watch
You might be able to pop it open with a pocket knife ... don't stab yourself though.
SOURCE: need instruction manuel for elgin fg010-007 sports
The movement in this Elgin is made by Citizen. After you change the battery, you need to reset the hands so that the watch functions properly. Select chronograph function with lower-right button. Then pull-out the same button. Push the upper left button to select the UTC, hour, and minute hands. Then use lower-left and upper-right buttons to make sure everything is aligned to 12:00 position. After setting the hands to 12:00, push in lower right button. Now you can set the time by selecting the SET using the lower right button. Pull out the same button and choose your time zone to set.
