Question about Alpine MRD-M605 - V12 MONO AMP 600WX1 RMS 2 OHM Car Audio Amplifier
I need to know how to remove the circuit board out of an Alpine MRD-605 amplifier. I need to solder the RCA plugs because they have become loose on the board. Please help. I get it to almost come out but something is still keeping it from being removed.:(
  • 113 Answers
First take all the screws out of the back of the amp when that is done there will be about 6-7 screws holding the board in place. Then you have to remove all the screws for the mosfets on the outside edges of the amp but make sure not to smear any of the heat transfer tape or heat transfer gel that is under the mosfets and then you should be able to take the board right out
Posted on Jul 05, 2009
Broken alpine amp terminals
THAT USEUALLY MEANS UR AMP IS WAY 2 POWERFUL FOR UR SUBS
Feb 10, 2010 | Alpine MRD-M501 Car Audio Amplifier
How do i fixs cur code
yes you have a internal fault of the amp. the circuit that puts it into safe mode is bad and that is a very small chip on the board know as a op amp. needs to be repaired.
Dec 28, 2009 | Alpine MRD-M1005 Car Audio Amplifier
Programing my alpine mrd-m1000
Hello steve1914,
You can download a PDF copy of the manual here. There's no cost for the download from Crutchfield.
Hope this helps.
May 29, 2009 | Alpine MRD-M1000 Car Audio Amplifier
CUR on alpine MRD M 605
check your ground and make sure you battery power is connect properly
Apr 14, 2009 | Alpine MRD-M605 - V12 MONO AMP 600WX1 RMS...
Need help!!!!!!!!!!!!!
ALPINE ELECTRONICS OF AMERICA, INC.
19145 Gramercy Place, Torrance,
California 90501, U.S.A.
Phone 1-800-ALPINE-1 (1-800-257-4631)
Mar 16, 2009 | Alpine MRD-M500 Car Audio Amplifier
Alpine MRD M301 just flashes
disconnect all inputs and outputs then restart it if problem persists you have a internal solder bridge youll need to have it repaired by authorized repair shop or buy a new amp at wholesale from this site:
www.godspeedaudioheaven.com
Mar 11, 2008 | Alpine MRD-M301 Car Audio Amplifier
Alpine mrd-m500
Hi SPDGOD,
Could not find exact, but close manual.  It is the MRP-M450 mono block amp from alpine.
Go to this url and view in Adobe. Print it if you need to
http://vault.alpine-usa.com/products/documents/OM_MRP-M450.PDF
Oct 19, 2007 | Alpine MRD-M1005 500W x 1 mono subwoofer...
RCA inputs bad
If you got the exact same ones, you should be able to simply pit them back into the same holes. if you did not get the same ones, look at the open holes, two should be connected together, and two are separate. Hook the two that are connected together to the ground part of the jacks, and the middle connections of the jack to the other two holes. if this does not make any since, send a picture of the jacks and the board so we can look at it for you. Good Luck
Jun 19, 2007 | Alpine MRD-M1000 Car Audio Amplifier
Alpine MRD-M605 - V12 MONO AMP 600WX1 RMS 2 OHM Car Audio Amplifier Logo
123 people viewed this question
Top Alpine Car Audio & Video Experts
Robert Salgado
Robert Salgado
Jeffrey Turcotte
Jeffrey Turcotte
Marvin
Marvin
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
