Question about Whirlpool Calypso GVW9959K Top Load Washer
My Whirlpool Calypso top loading washer (purchased in June of 2002) is starting to leave brown or dirt colored marks on clothing and sheets (I think they are permanent!) - I don't see any obvious place that this could be happening when I inspect the interior of the washer. Based on the shape and form of the marks, it looks like the marks could be coming from the clothing getting caught under the center agitator thing during the spin cyclet- but I really have no idea where they are coming from.
Posted by danadoug on
  • danadoug Apr 06, 2009
    I never have used cold water for washing - always warm and hot. If I use powders then they leave residue on the dark clothes. Based on some other suggestions, I did wash a white towel with a gallon of vinegar. When the cycle was done, I noticed a film of brown stuff seeping up from where the sidewall meets the bottom plate part - I wiped it off and it was the same color that has been marking my stuff. It doesn't seem right that I can't use softener and liquid detergent - wouldn't that be a flaw in the washer then? Also, just as a note, I called Whirlpool Customer Service today - apparently there was a lawsuit regarding the Whirlpool Calypso and they are sending a repair person to replace the U-joint for no cost...interesting.
  • kpmfire Apr 20, 2009
    I have the same thing happening. It just started a month ago. I put bleach though it and thought it had taken care of it, but today it is back. I have no Idea what to do. Call a service person or just get a new one.
Anonymous
    Scholar:
  • 102 Answers
Run the washer empty with vinegar on the hottest, longest cycle. Usually this is caused from fabric softener and liquid detergent build up. Use powder detergent only and don't use cold water to wash in all the time. Only use cold water for your bright, finer cloths. Cold water use causes detergent build up.
Posted on Apr 06, 2009
Anonymous
I have the same machine - almost 6 yrs old and recently leaving brown marks. Coincidentally, the agitator got stuck in an awkward position and trapped clothes underneath - when we took the white cap off of the middle part of the agitator there was a thick layer of brown dirt coating the entire inside of the unit (over the screws, etc.). The dirt must have been leaching into the laundry and also got stuck in the seam where the perforated part of the basin meets the top. I have no idea where the dirt could have come from, but if you put detergent directly on the spots before drying the clothes I have been able to get them out without staining. At this point we have opted not to repair the machine and are just getting a new one instead. I am really disappointed by the service and quality of this product.
Posted on Apr 20, 2009
Our Whirlpool Calypso model #GVW9959KL washing machine has started leaving light colored marks (kind of look like lint, but won't brush off like lint might) on dark clothes. Do you know of a way to...
sounds like you might have mold inbtween the tubs and its starting to wash loose and get on your clothes. try a washer cleaner like washer magic and see if that helps.
Feb 20, 2011 | Whirlpool Calypso GVW9959K Top Load Washer
Lg washer leaving black greasy marks on clothes
This is usually to do with fabric softener. Dilute it with more water. The fabric softener makes clots, and these make the marks on your clothing.
Hope it helps
* If you found this solution helpful, please vote positively.
Feb 17, 2011 | LG WM2077CW XL Front Load Stackable Washer...
Starting to leave brown oily like stain on clothes
The first place that I'd check would be the small metal screens inside the openings on the water inlet valve. They can get really rusted, epecially in areas with hard water, so I would recommend removing the water supply hoses and take a gander at the screens. They can sometimes release the iron oxide into the wash water and cause brown stains or blotches on clothing. Hope this helped and best wishes.
Sep 07, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore Calypso Washer is leaving dark brown stains on clothes
hi is the machine noisy on spin cycle if so ur bearings have gone
May 11, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore elite dryer burn marks on cloths
The brown stains are likely coming from the felt drum seal. The OEM adhesive is tar based - and after time and use - breaks down.
You'll need a new felt seal - and the adhesive that is used should be silicone based... eliminating the brown streaks.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 22, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso GVW9959KL1 ruins clothes
I can assure you this IS a common problem. I can't tell you how many customers I have had in the past that complained about their Calypso's leaving the same marks on their clothing. The problem occurs because of the suction on the clothes as the washer extracts water from them during the final nunator cycle. The nunator is the wash plate that the clothes get caught in. The manufacturer's cure for this problem was to come up with a modified control board that reduces the final nunator time and minimizes the suction action on your clothing. The replacement control board part number is 8571359. I have ordered and installed this board on a few Calypso's. I'm surprised that nobody advised you of this in the past. If you call Whirpool back and they deny this, I got this information from them. It may be worth your while to contact them again to see if there is a recall on this and if they would cover the cost of the repairs.
Aug 22, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Grimy brown residue
the leveler and universal need to be repaced these are the parts underneath the plate in bottom ..residue and corrision are coming off and getting redeposted inside also cke recirculating tube right rear sometimes gunk will accumilate there but my money is on the universal and leveler both come in a repair kit
May 28, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool calypso washer black streaks
to all that are having a problem with these calypso washers... if you have paid for a repair then you need to check out the lawsuit... calypsosettlement.com and see if it applies to you.
but if you are getting a mark or a residue on your clothes, then look at the inner wash plate gasket, where it meets with the outer stainless steel tub. if there is a gap between the gasket and the tub then thats where the marks are coming from.
it happens alot and thats not covered by the settlement, but its not too bad to replace the inner wash plate. you need to remove the cabinet, then the tub cover and the innerwash plate dome. then 6 screws and the cover will come off.
replacing the inner wash plate will solve the stains and get you a few more years of use until you have to buy a new washer as more items may fail.
Apr 09, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
687 people viewed this question
Marvin
Marvin
Michael Thomas
Michael Thomas
