Question about Rheem 40 Gallon FVR NATGAS Low WATER HEATER 6YR 22V40SF
Water heater is bubbling with the sound of sediment
The water heater makes a bubbling sound. There is sediment on the bottom of the tank. How do we drain it and get rid of the sediment?
Posted by the4tapps on
Mike Wenger
    Problem Solver:
  • 14 Answers
You can try to flush the sediment with the water and power on. Just hook a short hose to the drain and shoot it into a clean white bucket (so you can see what comes out). The drains on most water heaters are far too constricted to flush anything but the small particles, so if your problem continues you might consider replacing the factory drain with a short 3/4" dielectric pipe nipple, a 3/4" full port ball valve, a 3/4" m.i.p. x 3/4" garden hose male and a garden hose cap with hose washer. That will give you some serious flushing capability.
If all of these steps won't get rid of your noises take comfort in the fact that the noise may be a nuisance to you, but it is not doing any really bad damage to your heater. I also strongly recommend getting a water softener to prevent this problem from ever happening again.
Mike
Posted on Apr 05, 2009
Anonymous
  • 4 Answers
Install waterhose to the draindown valve at the bottom, turn off the supply valve at the top, either break the cold supply line or flit the lever of the temperature and pressure valve ( to break the vacuum ) If it is electric, turn off the breaker, if it is gas turn the red knob on the bottom to the off position. Let all the water drain. Open the cold water supply valve and let it run for around 15 to 30 minutes.
Close the T&P valve ( or tighten the supply line ) Open a hot water fixture ( I would use the tub ) When water starts flowing from the tub faucet with no air, turn on the electricity or gas valve. This should be don once a year.
Anonymous
I've faced this with a number of hot water heaters, both gas and electric. It is possible to get rid of the sediment buildup. The replacement of the factory drain will help some, however, it may not get all because some buildup settles back down in the water faster than the water could move it around to drain out. The drain doesn't reach all the way down to the bottom of the tank, but rather an inch or 2 above the bottom.
One solution depends on how much work you're willing to do, or pay someone to do. You'll need access into the tank for a tool you'll have to rig up. For electric water heaters, remove the lower heating element. The tool: Take any larger size shop-vac that sucks water, using adapters and/or ducttape, attach a flexible rubber hose to the shop vac. This hose must be small enough to fit into the element hole. It also needs to have the largest inner diameter you can get. For the most part, the sediment is not powder but mostly chunks - some the size of small marbles, some the size of golf balls, some the size of BB's. All of which is easily crushed and comes apart when pressed on. Using the shop vac /rubber hose combo tool, insert the hose into the element hole and vacuum away moving it around inside as you go. You'll need to expect this to take some time. It's slow. Large chunks can be crushed using the hose or using a pole or rod that fits inside to crush it. You may not be able to get 100% of it, but with patience, you can get about 85% - 90% I'm estimating, and enough to have the water heater working well again.
To get 100%, you would need to remove the water heater to outside, and allow for it to lay down, again using the vacuum hose, and working away at it until you get all of it. Expect it take time. Possibly over an hour or two working away at it. (It depends on how much work you're willing to do, or how much money you're willing to pay someone else.)
For gas water heaters, there is no element hole (a large hole), you'll have to get a smaller hose meaning that the vacuum process will be even slower. Check your heater to see what the hold size is. Remember, the hose has to easily fit inside the pipe hole and be able to be moved around inside and out. To make the job "easier", again remove it to outside, and turn it on it's side or better - upside down using the holes at the top of the water heater and vacuuming from underneath.
It takes time but it can be done, and has been done by others.
Posted on Sep 15, 2009
Richmond 40 gal water heater from 2003 gurgles loudly when refilling, is that normal
I'm not sure what you mean by "gurgles when refilling." If you mean that it is making noise when heating the water, that is usually a sign that sediment has built up in the bottom of the tank. This results in the surface of the tank bottom to overheat and the sound you hear is the water flashing to steam. This usually results in tank failure as the glass lining will crack an the tank will rust out. If it's not too late you could drain and flush the tank to try to remove the sediment but if has hardened to a solid mass it won't come out.
Sep 14, 2016 | Rheem Richmond 40 Gal Nat Gas 6 Year Power...
Getting popping noise from water heater after shower
Popping sound is caused by sediment built up in bottom of tank: air bubbles get trapped when heating starts, and then they crackle, rumble etc when free.
Clean out sediment:
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html
http://waterheatertimer.org/pdf/How-to-descale-water-heater.pdf
The steps vary by type of water heater, gas or electric
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Jun 27, 2013 | Water Heaters
Rust in water heater tank
the tank needs flushed out ! heres how. Water heater manufacturers recommend flushing sediment from your storage type water heater periodically.
If your water heater is gas, set the gas valve to "Pilot" to prevent the burners from coming on while you are flushing it. If your heater is electric be sure to turn off the circuit breakers. With an electric water heater, if the water level drops below the heating elements and the thermostat turns the elements on, the heating elements will probably burn out quite rapidly. Connect a garden hose to the drain valve at the bottom of the tank, Close the shut off valve on the cold inlet to the water heater. open the temperature/pressure relief valve at the top of the tank by lifting the lever. Leave the valve open. Open the drain valve at the bottom of the heater allowing the water to flow out through the garden hose. when the water is clear your finished. close pressure relief valve on top of tank and turn water back on.
Open a hot water faucet in your house, and let it run until no air bubbles come out.
Turn the heater back on, and with gas units re-light the pilot light if necessary. good-day !
Apr 24, 2012 | Water Heaters
We aare in a home unit with a Rheem 80 gallon electric hot water system installed JANUARY 2011 it and it has issued terrifyingly loud rumbling noises. When I pulled the pressure release lever i t...
1) The pressure release valve is operating correctly and the sound it made is typical.
So pressure release is okay.
Always protect yourself from very hot water that can spray out of pressure release.
2) Rumbling sound is typical sign of sediment build-up inside tank, and usually indicates that tank needs to be cleaned out.
Seems odd that a brand-new tank could have sediment after only 8-9 months.
Did somebody recycle a 'new-looking' heater and sell it as 'new' heater?
Look at label on side of tank, and find brand and serial number to find actual age of water heater:
http://waterheatertimer.org/pdf/WaterHeaterSerialNumberDecoder.pdf
3) Because sound might not be sediment.
You can add a comment and it will send e-mail, and I will continue to answer.
No reason to be terrified of water heater. They are very safe, and homeowner can fix electric water heater same day for a few dollars.
4) Please listen to exactly where sound is coming from.
5) If sound seems to come from the pipes, and pipes are vibrating, then the plumbing is suspect, for example a check-valve, or pressure valve, and we can talk about that when you add a comment.
6) If sound is from inside the tank, then I suggest you turn off power, let water cool, drain water heater, open bottom of water heater, remove element, and check for sediment.
http://waterheatertimer.org/How-to-clean-sediment-out-of-electric-water-heater.html
7) Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 05, 2011 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
Why does my self cleaning gas water heater make clicking noises?
zdriscoll-
All tank water heaters make some amount noise, clicking and "snapping" sounds, particularly after much of the hot water in tank has been used (like after a long shower) and has been replaced by cold water that is being heated vigorously.
If the noises are accompanied by poor or erratic performance, or obviously if something malfunctions, you may require the services of a repair connection.
Hope this helps.
Regards,
DIYpro
May 03, 2011 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
My water heater makes hoise what can i do to make it quiter
You posted under electric water heater.
1) Gas or electric, the noise is from sediment build-up inside tank.
Once sediment builds up, the only way to solve problem is to clean the tank out.
2) To restore full efficiency to electric water heater and stop the noise, clean the tank:
3) To clean gas water heater is more difficult and less successful:
4) To prevent sediment problem, flush water heater each 6 months before sediment can build up.
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html#flushelectric
5) Other things to know for water heater maintenance.
http://waterheatertimer.org/Replace-anode-rod.html
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html
Mar 21, 2011 | Rheem 30 GAL ELEC SHORT Water Heater 6YR...
I have a 50 gal rheem water heater, its making a clicking noise i have discovered if i shut off the cold water supply it stops, when i turn it back on then the clicking starts again, my t&p has popped...
sediment build up is usually causes thumping and noises from tank. it needs flushed out. models, where the heat source is beneath the tank. The burner heats the water under the sediment, leading to a build of steam. The steam finally escapes as bubbles, which can cause the sounds.
have a good day !
Mar 14, 2011 | Rheem Water Heaters
I have a Rheem82v52 2 that gurgles 24 hours per day short of Pepto Bismol, what will make it quieter???
The sound is from sediment.
Sound signals need to clean out tank:
Electric water heater can be restored to full efficiency after cleaning:
http://waterheatertimer.org/Water-heater-will-not-drain.html
To find age of Rheem, look at 2nd and 3rd digits on serial number, for example 06 is 2006.
Rheem normally uses 4500Watt bolt-in type element, available at home center or hardware.
Feb 12, 2011 | Rheem Water Heaters
Where do you put the filtration system if you want to eliminate all sediment from your hot water tank. Doe's it go before or after the softener and into the hot water tank?
There are two water lines connected to water heater.
One is marked Hot and the other Cold.
The shut off valve is on the Cold line.
To eliminate sand and dirt from entering your water heater, the 'sediment' filter should be installed on Cold line.
Sand and dirt are sometimes called sediment, but this type of sediment is not the same as calcium carbonate sediment that accumulates inside a tank that receives hard water.
When you have hard water, then water heater makes calcium carbonate 'sediment' deposits that accumulate in bottom of tank. A 'sediment' filter will not prevent this problem.
If you have hard water, to prevent calcium carbonate from forming inside tank, you need a water softener.
Water softener will prevent calcium carbonate sediment forming inside tank.
However water softener will shorten life of water heater anode rod.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on water heater.
Jan 04, 2011 | General Electric GE SmartWater Household...
Water heater makes bubbling sound
If your tank is very old than there might be accumulation of rust and debris on bottom of tank, try and purge the tank put a garden hose on the lower most water fitting at the bottom of your unit and drain the tank. Be sure to shut off the water inlet. You might even have the booklet still taped to the side of your unit and it will explain how to flush your unit.You might also want tot think about replacing your anode rod it is probably toast if old unit.
Nov 20, 2010 | Rheem 50 Gallon FVR NATGAS Water Heater...
Rheem 40 Gallon FVR NATGAS Low WATER HEATER 6YR 22V40SF Logo
201 people viewed this question
Top Rheem Water Heaters Experts
Bill Johnson
jdthefixer
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
