Question about Oregon Scientific Lwb0997110113004 Thermometer, Tht312/Blrw Clock Radio
Getting temp from outside unit to inside unit. Mod#BAR122HGLA
I have a grandson who visits often, likes to punch the buttons on the inside unit. I am having trouble getting the outside temp to show up on inside unit. Any suggestions appreciated. Don Carlisle Model#BAR122HGLA
Posted by fowlercarlis on
Anonymous
    New Friend:
Based on a suggestion from another thread, I removed the batteries from the base unit, waited until the display went blank,then replaced the batteries. After a few seconds the outside temp started displaying again.
Posted on Dec 16, 2009
Anonymous
    Problem Solver:
  • 8 Answers
Have you got this solved?
Posted on Jul 11, 2009
No outside temp in de display only - - -in thedisplay i see the room temp. No outside temp. I have checked the outside transmitter end i see the red flash.
my unit tells me to insert fresh batteries into the outside sending unit first. then insert new batteries into the inside receiving unit. after the outside temperature shows up, then can reset my inside unit's time, choose F or C and
switch channels. please try changing channels if your
outside temp doesn't show. you can do both units in the house then put one outside after they work properly.
Mar 29, 2018 | Home
My Hammacher Schlemmer Projection Alarm Clock and Weather Monitor will not project the outside temp. It only projects the inside temp. How do I change? Also, can't change the time zone.
No solution but to return it...very annoying product but yet I like the projected display, very sharp and bright. The replacement was much better, it loses connection with outside transmitter often..but occasionally we see the outside temp
Dec 28, 2013 | Hammacher Schlemmer The Projection Alarm...
I have a 433MHz cable free indoor/outdoor thermometer. It has worked perfectly for years. Just changed the batteries in the main unit and the remote. The main unit will not pick up the outside temp. I...
You have to push some buttons to tell the MAIN unit to scan, then put battery into the REMOTE, set channel, and hit reset through a little hole. And the MAIN should see it.
Sep 17, 2011 | Oregon Scientific Wireless IndoorOutdoor...
I have a Rheem Heat Pump unit. This winter, the outside unit fan at times trips off, but the inside unit keeps running continuously. I woke up one morning & it was 62 in the house. The inside unit ran...
Dear Friend!
Due to very low ambient temp, the fan will not run. Once the pressure build up, it's automatically run for some time and again cut off. But if you keep Heat mode and still tem not raised in your room means the reversable valve not working and hence the compressor and out side fan also will not work. Keep "Heat" mode and temp setting +29 to get better heat. Hope is it helpful?
Dec 10, 2010 | Heating & Cooling
I have this model and the outdoor temp sensor isnt working, and yes both modules have brand new batteries in them. what should i do to get the outdoor temp sensor to work.
My outside display stopped working, but the inside display still worked. I found that one of the two batteries in the inside unit was almost all the way dead. Once I replaced both batteries the outside display worked. I also checked the batteries in the outside unit. After all batteries were installed, I pushed the small button that is inside the battery compartment on the outdoor unit. It's now working perfect..
Oct 10, 2010 | Acu-Rite Acurite Wireless Weather...
Norcold mod 1200 does not cool well in Az. during the summer time
air circulaton over the cooling unit on norcold is critical get out you owners manuakl look up baffels and make sure all are in tact and also no animals have made a home behind you refer you have done all you can do inside the problem lies on the outside of the refer where the cooling unit is
Jul 22, 2009 | Thetford Norcold DE0051 Refrigerator
Inside unit running outside want come on temp on
check circuit breaker in house panel labeled a/c or outdoor unit
check box near outdoor unit for a breaker or fuses
some thermostats have a 5 min delay when switched to a/c
check for external reset buttons at outdoor unit some are red depending on brand
check that all wires are intact at outdoor unit------none cut or hanging and not hooked to anything?
Jun 19, 2009 | Honeywell Programmable Thermostat Heater
Oregon Scientific Lwb0997110113004 Thermometer, Tht312/Blrw Clock Radio Logo
971 people viewed this question
Top Oregon Scientific Audio Players & Recorders Experts
Muntejaya Ginting
Muntejaya Ginting
STEVE SPAM REMOVER
Are you an Oregon Scientific Audio Player and Recorder Expert? Answer questions, earn points and help others
