Belling XOU252 Electric Single Oven Logo
Question about Belling XOU252 Electric Single Oven
Fan oven wont heat up
I have a belling xou60f single fan oven that the grill and light are working but the oven wont heat
Posted by sanda_pinner on
  • Anonymous Mar 27, 2014
    oven wont heat up and fan doesn't go round
  • Anonymous Mar 28, 2014
    The fan on my belling fan oven is not working
Barry Coates
  • Belling Master
  • 3,463 Answers
If fan is workintg, but no heat, then replace oven element.
If no heat or fan, then make sure timer is set on manual and not on auto
Please rate my solution.
Thanks.
Posted on Jul 01, 2009
6helpful
Fan and grill works, grill actually cooks but oven wont heat up - is this the element
Without a doubt this is the element that is faulty.
It is located at the rear of the inner oven compartment behind a removeable cover.
6helpful
My Belling oven has no heat, but the fan &
If the fan is working o/k, then there is little doubt that the oven element has failed.
This is quite common with fan assisted ovens.
The element is usually located at the rear of the oven compartment behind a removeable cover.
7helpful
Oven not heating up [fan works] the oven is a belling xou 163 the grill works but the oven does not warm up
It wilbe a faulty oven element, you will need ti fit a new one.
It is located at the rear of the oven, behind a removeable cover.
Thankyou.
1helpful
Grill is working but oven wont heat up
You need to replace the oven element, it is located at the rear of the oven behind a removeable panel.
Please rate my sol;ution.
Thanks.
2helpful
The oven blew the electrics and now the heating does not come on. the grill and fan both work but not the oven
If the fan is working o/k, then you need to replace the oven element, located at rear of oven compartment behind panel.
Please rate my solution.Thanks.
FAN OVEN DOES NOT WORK
most common fault is that the ring element has blown. fairly straight forward repair for an expert.
Mar 12, 2009 • Ovens
4helpful
Fan and grill works but not heating up
Hi.
If the fan is working o/k, then you need a new fan oven element fitting.
Remove panel at rear of oven compartment, there you will see the element, undo any screws you can see to remove rear cover.
disconnect element taking care not to loose wires, and fit new element. test before you refit rear cover.
Plz rate this solution.Thanks
Belling oven
you will have to replace the main oven element...
Top Belling Ovens Experts
Marvin
Marvin
Lawrence Oravetz
Gil Shultz
Are you a Belling Oven Expert? Answer questions, earn points and help others
