The Night Owl CM-C20 does not have a specific wire color code diagram. The standard color code for security systems is as follows:Red - Positive Black - Negative White - Common Yellow - Video Signal Green - Data
the Maytag dryers would have the diagram either INSIDE the control panel, OR on the back of the control panel. Neither are color coded as there never was a color coded diagram ever printed. The diagrams do list the color of wires and show where they start and terminate. That is all a service tech would require to troubleshoot. If the diagram has been removed, you could try an online search.
Why do you need a wiring diagram for a O2 Sensor? They are 4 wires and when you replace the sensor, you get a OEM. If you are going to get a Universal, it comes with a wiring diagram (GREY go to WHITE) and Black to Black
Red wire= 12V switched Yellow= 12V constant (memory) Black=ground Blue=Amp remote wire Pink=emergency brake safety Speaker wires are paired by color with black stripe being negative
