Televison & Video Logo
Question about Tvone TV-207 Television
How to remove factory a05a06-01-v08.05 in government tv
Soundar Rajan
    New Friend:
NOT USE FULL
Posted on Dec 05, 2020
sathik
    New Friend:
In my government kalaigar tv i don't have the option for factory settings but in my tv remote i have the buttons sleep, recall ,zoom, lock .. . what i did , i hold the menu button 15 seconds then changed the r g b colors that it. now in my tv factory messages does not appearing .
Posted on Apr 19, 2014
1helpful
Toshiba locked
It isn't the government. It is a SCAM!
Even if you pay the extortion money, nothing changes.
I received this information from another expert, in an alike problem.
The solution is to remove the internet access to the computer.
Then put the Restoration disk in your optical drive. (CD/DVD drive)
When asked choose Full Install. Destructive Installation.
The computer will go back to day 1 from the factory.
ALL personal information will be lost.
ALL installed, or downloaded programs, will be lost.
Regards,
joecoolvette
2helpful
I need tamilnadu government free all models circuits
I need circuit diagram for ctv11409 module TV That is government provide tv for tamil nadu....
What this mean p1756
P1756 what does this mean: It is transmission related, difinition is: transmission governor pressure not equal to target...its a transmission code this is a common failure... have seen these governer pressure sensors fail often.... most codes are governer pressure sensor volts too high or low, governer pressure sensor not equal to target.. Most of the time you replace the governer pressure sensor and soleniod.. I would recommend you to fix this problem if not you will end up burning the clutches in the trans... The trans pan needs to be removed....the sensor is bolted to the valve body and is located on the pass front side of the valve body.
Want to remove the governer
the only way to get rid of the governor is to buy a performance tuner that is capable of shutting off the governor.
3helpful
2answers
I bought 15 used MSNTV2 units from a government liquidation auction with the hopes of reselling them for a profit. I failed to realize that these are password protected machines and there isnt much you can...
Ruismall is halfway there. You must hold down the MSN power button on the keyboard while typing the magic number 32768. Wait a while until the TV screen goes blank, then power up again. I had to power up twice, but I did finally get the "Welcome to MSN" screen.
Y wont my brand new xr250 2005 model go faster than 90kms
It is possible that your bike has been governed from the factory to only reach a certain maximum RPM, they do this so you don't inadvertently over rev the engine and blow it up.
If the bike is not governed you might have to re jet the carb, altitude and other factors can change your fuel/air requirements and cause improper operation of your fuel system therefore the maximum RPM.
Top Tvone Televison & Video Experts
Marvin
Marvin
Are you a Tvone Televison and Video Expert? Answer questions, earn points and help others
