Sony PS-LX300USB Turntable Logo
Posted on Apr 05, 2009
I need to determine appropriate stylus replacement for the Sony PS-LX300USB Turntable
Anonymous
Level 1:
  • Contributor 3 Answers
  • Posted on Sep 23, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
6721
Points
10
Any stylus should work i think radio shack sells them for pretty cheap and I know for sure that best buy sells them for cheap thats where I got mine. Best though from what I can remember is diamond tip but very coastly.
1helpful
I just replaced the stylus on my sony PS-LX300USB turntable, but now there is a constant static on even my new records
You have either knocked the connections to the cartridge causing a loose connection, or not seated the stylus right. Or you have static build up, which can be caused by poor earthing.
No sound with Sony LX300usb turntable
I just received the Sony PS-LX300USB turntable but cannot play sound through the computer speakers. States to setup Playback USB Audio
CODEC which shows working and Recording it shows Microphone USB Audio CODEC which is working. How do I get sound???
How do I connect a usb turntable to a Yamaha HTR 6230? Sony turntable PS-LX300USB preamp switch set to 'line'
hi,
Select the switch to line. Then connect the red and white RCA pins to the corresponding red and white sockets of MD/CD-R play input of Yamaha. Select the MD/CD-R by pressing the button on the remote. Then play the turntable.
OK
While trying to replace the needle/stylus for my turntable, the metal part (possibly called a cartridge) came out instead ... now i can put it in and will stay but it is just resting there, it feels as if...
Depending on the cartridge design the stylus is part of an assembly that typically just slides out. It will look like this if you have the original one...
http://www.lptunes.com/Elliptical-stylus-for-Sony-PS-LX300USBE-turntable-p/stpslx0300usbe.htm
The whole thing just presses in and friction is all that holds it in place. The actual stylus ("highly polished special elliptical diamond") is that little tiny point on the skinny metal piece ("thin wall aluminum alloy cantilever"). THAT part is NOT a subassembly for you to take off.
Just received our Sony PS-LX300USB turntable, but cannot get the stylus to stay on. Any suggestions on how to install the stylus?
Hold the stylus at an angle, rear up/needle down. Put the rear of the stylus in first and then push the front of the stylus up and clip into place.
Which stylus number did you use?
D.
What brand and model number of stylus can I use to replace the broken one from my sony PSLX-300usb?? thanks.
It generally goes on the cartridge fitted. Sometimes you can see the number on it, other times it will be in the manual. Some Sony models just have the model number of the turntable as it. A Google search will come up with replacements and price.
PS-LX300USB Turntable: I have hooked up the sony turntable to laptop, but...
Have you though of using a pre-amp? You'll probably need to go turntable --> pre-amp --> soundcard input to get acceptable sound
Is there a mac os x driver available anywhere for the sony ps-lx300usb turntable?
You do not need a driver for mac... just plug the usb cable into your mac... go to sound settings in system preferences and set USB to default audio input device... then install audicity... it is free and open source... play your record and hit record in audicity. done.
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
ZJ Limited
ZJ Limited
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
