Question about Mitsubishi DD-4000 DVD Player
Dvd player will not load
Player says disk error
  • Anonymous May 11, 2010
    Unless there is dust on the lens that you can blow off with a can of compressed air there isn't much an end user can do about this error. It will take some diagnostic effort to determine the exact cause.
Anonymous
    Problem Solver:
I Have The Same Model At Home Right Now.
When I Get That Problem, Its Usually The 'Small' Plastic Drive Gear Attached To The Electric Motor That Drives The Big Plastic Gear That Operates The DVD Itself. (Makes The Disk Spin In Other Words)
Turn It On And Load A DVD In The Player, If You Hear A Little [Grinding/Meshing] Sound, It Means The Drive Gear Has Slipped Down On The Electric Motors Shaft Causing The Unit To Flash "Not Loading"
Posted on Nov 29, 2009
  • Anonymous Nov 29, 2009
    Clarification Request Needed
Anonymous
I purchased anew one.
Posted on Apr 06, 2009
Cd says loading error and wont play
disks re lazer screen needs cleaning disk cleaner
Aug 12, 2012 | Alpine IVA-D100 6.5" Wide LCD w/DVD/CD/MP3...
Dvd player tell me disk error
this could be aproblem with the lens which is unable to read the disk. this could be caused by accumulation of dirt on the disk sensor. open up the cover of the dvd player to access the lense and clean gently with a lense cleaner(a liquid purposely meant for cleaning the lense) apply this liquid on a soft piece of cloth and clean. close back the cover and power the dvd player it should now be able to load the disk
Sep 17, 2011 | Philips Magnavox DVD/VCR Dual Player
When i tryt to play a dvd in my philips DVP3144 it keeps flashing load and wont play
Try a cleaning disk in the player to remove accumulated dirt from the laser eye. This accounts for 99% of load error and insert disk in player errors
Please rate my help++++Thanks for using FIXYA
Feb 27, 2010 | Philips Magnavox DVD/VCR Dual Player
I keep getting a Bad Disk error when loading DVDs that I know are fine. When there's no disk loaded, all I see is the blue load screen with the message "loading" in the upper left
there is a ribbon cable in the DVD player that connect the moving laser head to the main circuit board. When this cable becomes damaged from moving over time, it will claim that your DVD is bad (even though it is not). Best to scrap the player and buy a new one.
Oct 07, 2009 | Cyberhome CH-DVD 300 DVD Player
DVD will not load
Firs try to clean the lens with CD/DVD cleaning disk (it might be $1-5 depending on store)
Also check if DVD disk not upside down.
Also chek the DVD disk for scratches
Good Luck
Dec 25, 2008 | Daewoo DVG-9200N DVD Player
Disk Error
You can not fix this problem because the player does not read dvd recordable disks
Sorry!
Dec 18, 2008 | Toshiba SD-2700 DVD Player
Dvd loading
mine kinda has the same problem but it only happens with one movie Hairspray but it doesn't say error it just says loading for hours until i restart this system in order to get the DVD out. Need Help!!
Feb 16, 2008 | Sylvania SRD3900 DVD Player/VCR
Dawoo DVD Player showing No Disk error
you have dirty lens, try to cleaning with 100% cotton buds. or you have damage laser eye, or broken flex ribbon wire, but first you have to do is to cleaning the lens with cotton buds.. if not reading after you clean the lens! change the laser eye and flex ribbon wire.
Aug 31, 2007 | Daewoo DVDS151 DVD Player
Mitsubishi DD-4000 DVD Player Logo
215 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Ekse
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
