I have intel d101ggc desktop board. recently i formatted my system and downgraded it to Win 2000 from XP. I have installed all the drivers available in the motherboard CD but still the display doesn't seem proper. it looks like as if a display driver need to be installed. I have searched net to get the display driver. but all in vain.
You are installing the driver for the desktop board A044412A while your board is D101GGC so why are you installing that driver? Install your compatible driver.
If you have a valid Win XP Pro CD and want to install the operating system you'll need to format your hard disk drive. If you have allot of data on you're hard disk drive, (In Win 2000) Suggest you create a second partition within the free space of you're hdd and install windows XP Pro. Boot you're system with the XP CD. Pay close attention to the display screens. Follow the instructions for creating a second partition.
Format the new partition. (Quick). Install windows XP on the new partition. Once completed you can copy your personal data to win XP.
If you choose to keep the win 2000 partition and you do not wish to have a dual boot system than remove/delete the root files from the 2000 partition. These files; Autoexec.bat and Boot.ini. You're new XP Boot.ini should read like this;
[boot loader] timeout=30 default=multi(0)disk(0)rdisk(0)partition(1)\WINDOWS [operating systems] multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Professional" /noexecute=optin /fastdetect /usepmtimer
Once you're satisfied an no longer need win 2000 use windows diskmgmt.msc from the run command to delete the win 2000 partition.
Win 2000 uses a FAT16 where Win XP uses the FAT NTFS.
The problem is due to that you are not installed sound driver in your computer.. you just need to install sound driver that are given by your motherboard CD ... If you dont have then you can download from internet...
Intel Desktop Board D945GCNL HD Audio Controller 5605 Windows Vista(32/64)/XP(32/64)/2000
Installs the Realtek audio driver version 5605 for Intel® Desktop Boards.
IMPORTANT: Audio drivers may fail to install in Windows* XP 64-Bit Edition. Symptoms may include error messages, such as "Error in installation" or "Unknown error". Microsoft's Update for Windows XP x64 Edition (KB901105) fixes this issue. After installing this update, the audio drivers for Windows XP 64-Bit Edition will successfully install.
Next up select Windows XP Professional as your operating system. Now click, "Drivers." The first result should be the Realtek drivers, which are what you're searching for. Download them. Once they finished downloading open the file and the drivers should be installed automatically.
If there's anything else I can help you with, let me know. If this solution solved your problem, please rate the solution.
in bios setup usually under security you can remove user passwords.
you get into safemode for 2000 and in control panel and remove it form users administrator account
If your not interested in to os systems then you can format
u cannot use linux and xp in single system.....because linux boot loader is highier version so it will not allow the win xp boot...u need to format the system and install the xp itself..thanks
