Question about Kenmore 53092 / 53094 Side by Side Refrigerator
Refrigerator not cooling
I have cleaned the first 2 coils under the bottom, my question is how do I reach the other coils, I used my vacuum and a brush but it won't reach
Posted by marychaffin on
  • marychaffin Apr 05, 2009
    thank your so very much
Anonymous
    Prodigy:
    An expert who has answered 500 questions.
    Sergeant:
  • 531 Answers
You have to get a condenser brush from appliance parts store
Posted on Apr 05, 2009
My Amana ABC2037DPS Refridgertor is not keeping items cool. Last time the serviceman came out he went into the back and "RESET" the unit. Does anyone know how to RESET the Refridgerator?
Most likely the coils under the refrigerator need cleaning. Unplug the refrigerator and remove the front, vented cover below the door. With a vacuum cleaner and crevice tool clean the coils off. It may also help the clean off the door gasket and apply a very thin coat of Vaseline. (Don't forget to clean the refrigerator edge that makes contact with the gasket.)
Sep 20, 2013 | Amana Easy Reach AFD2535DE Bottom Freezer...
My whirlpool ED5VHEXV001 frig is not cooling well; freezer is doing just fine. Found beaucoup dust clogging the heat dissipating coils under frig. Cleaned 1st row of heat dissipating coils. Frig is now...
You can purchase special cleaning brushes to do that - BUT since I purchased one, I used it when I first got it and then put it away somewhere and can't find it. So I had to figure something else out, and what seems to work the best is to turn on the vacuum and put on the floor in front of the unit and then use an air compressor blowing it out from the rear. While it does blow dust into the kitchen, it seems to work well as cleaning out the condenser coils.
Aug 06, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
The freezer is running and is set to the coldest setting but still is not cold enough to freeze our food. Ice has melted and food in the freezer is beginning to thaw.
The condenser coils dissipate heat. If dust and debris accumulate around the coils, your refrigerator may not be able to cool properly, it may run continuously or it may stop completely as a result of an overheated compressor.
1. Make sure condenser is clean.
2. If you have a "rear mounted" condenser (black coil on back) make sure it has enough room around it for air to circulate. Not against the wall and if under cabinet should have about six inches clearance.
Rear-Mounted CoilsYou should clean rear-mounted coils once a year. Unplug the refrigerator before cleaning. Refrigerators are heavy, never tip one forward or backward. Never attempt to move a refrigerator without an assistant.
Vacuum or brush the coils. If coils have a filmy build-up, use warm soapy water to clean them. Take care not to spill or drip water onto the components of the refrigerator.
Floor Level CoilsYou should clean floor level coils at least twice a year. Unplug the refrigerator before cleaning. Vacuum or brush the coils.
Remove the grill from the front of the refrigerator and use a vacuum with a wand attachment to remove any dust and debris. The grill should snap off and on. Pull firmly toward you and possibly upward to remove the grill. If it does not come off with a modest effort, check for screws or retaining clips that may hold it in place.
Jul 10, 2011 | Amana ARB220RCW Bottom Freezer...
Refrigerator is not cooling
Have you cleaned the coils lately? If not, unplug the appliance after you've located the coils. They may be on the bottom or in back. Dust on the coils can hinder the cooling process. I purchased a good quality long handled brush from the Fuller company. Extend the brush carefully into the coil area, twirl and pull out. Do this for the entire coil area. You'll be amazed at the "fun stuff" you'll remove. You may also use the crevice tool of your vacuum cleaner. If your vacuum has a dusting brush that is small enough, that may be used as well. Also, pull the refrigerator out and vacuum the floor under it well . If the cooling doesn't improve, you will probably need to get a professional to check the refrigerant level.
Nov 01, 2010 | Maytag MFI2568AES Stainless Steel Bottom...
How to clean condenser coils on lfx25960tt
Condenser coils- The condenser coils dissipate heat. If dust and debris accumulate around the coils, your refrigerator may not be able to cool properly, it may run continuously or it may stop completely as a result of an overheated compressor. You should clean rear-mounted coils once a year. Unplug the refrigerator before cleaning. Refrigerators are heavy, never tip one forward or backward. Never attempt to move a refrigerator without an assistant. Vacuum or brush the coils. If coils have a filmy build-up, use warm soapy water to clean them. Take care not to spill or drip water onto the components of the refrigerator.You should clean floor level coils at least twice a year. Unplug the refrigerator before cleaning. Vacuum or brush the coils. Remove the grill from the front of the refrigerator and use a vacuum with a wand attachment to remove any dust and debris. The grill should snap off and on. Pull firmly toward you and possibly upward to remove the grill. If it does not come off with a modest effort, check for screws or retaining clips that may hold it in place.
Sep 04, 2010 | LG LBC22520S (224 cu ft) Bottom Freezer...
My Kenmore side bt side isn't cooling. The
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} 98d4754.jpgIf this was a slow moving loss you should clean the cooling coil under the refrigerator. Remove the bottom snap in grille and vacuum out the dirt and dust from the coil and anything else you can reach. You may need to make an extension with paper towel tubes flattened a little and tape to get into the cramped spaces. I use a piece of clear plastic pipe stuck in the suction with a long angled split cut on the cleaning end. Maybe also move the fridge out, vacuum and clean the flooring area also. (And every 6 months)
Apr 16, 2010 | Kenmore 57029 Side by Side Refrigerator
The refrigerator/freezer is not cooling it has power just will not cool
Try cleaning the dirt off the coils. First vacuum off all you can. If there are a lot of places the vacuum cannot reach, get a refrigerator coil brush at the hardware store and losen the dirt, then vacuum again.
Dec 01, 2009 | Sub-Zero Refrigerators
The bottom freezer on my Maytag BR22 is not
Look at the inside back wall of the freezer, If you see that it is built up with frost. You have a defrost problem. If not, check the coils under the bottom, make sure they are clean and not covered with dust. If so clean with vacuum and long brush. If they are clean, check the fan that blows on the compressor. Make sure it's running. If not you have a bad fan. Last be sure the fan inside the fridge is running.
Please rate solution
Sep 07, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Ge frig model 18-25, how to clean grills under the frig, full of dust and cannot reach with vacuum tool. This grill is about 8 inches behind the floor plate on the front of frig.
Go to the nearest home improvement store and purchase a rat tail brush. This brush is made for the exact problem that you are having. Ask an employee where to get a coil cleaning brush for your fridge It os easy to use and once you get the linrt and debris off the coil it is easily picked up by vacuum Good luck on your repairs
Dave
Sep 04, 2009 | Refrigerators
Kenmore 53092 / 53094 Side by Side Refrigerator Logo
155 people viewed this question
Top Kenmore Refrigerators Experts
gbob59
Dale Copeland
Dale Copeland
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
