Question about LG 42PX5D 42 in. Plasma HDTV
My Sanyo 46" LCD tv has sound but not picture.... The no signal sign keeps flashing around and I tried hooking my electronic device (Xbox360) to a different input but still does the same thing. I Tried to reset the television and had pic when it did that but then nothing, all cords are plugged into the proper colors and even tried using my DVD player to see of it was my Xbox and still the same thing... Sound with no pic
5 Related Answers
Anonymous
SOURCE: hooking up PS2 to Component hookups on 37" LG LCD
I have an older ps2 hooked up with componant cables too. Dis you buyt the special playstation componant cable?? If so, Make sure the right wires are in the right ports?? does it work with just the yellow cable in the Video??
Posted on Jan 16, 2008
Anonymous
SOURCE: sound no picture
I just had the same thing happen to my tv today. I tried taking cables out and putting them back, different antenna, everything. Finally phoned the LG contact number and they are sending someone out early next week to do a software update - free of charge! They were so helpful on the phone and a pleasure to deal with - even gave me a short term fix: turn tv on; unplug antenna, change the channel then plug the antenna back in ... picture is slowy returning using this solution.
I would recommend to anyone with this or a smilar issue to call the customer service line. Big bouquets to LG - I love their products! And their customer service is outstanding!
Posted on Nov 22, 2008
Anonymous
  • 60 Answers
SOURCE: need some sound to my home theatre system
Hey gr37_98:
1 thing to keep in mind with HT (home theater) systems is that when selecting a particular function that the input to the receiver matches the output to the TV/monitor. Example, you can play dvd's just fine because the HDMI output from the 958 matches the input to your monitor. Many consumers are under the mistaken impression that the home theater receiver can convert the HDMI to some other format, i.e. digital co-ax or optical. This is not the case. To use some other input the receiving device must have the same function & that particular input must be selected in order for the receiver to amplify it.
That being said, when you previously tried the digital co-ax connection did you specially select that input on your HT receiver? If you didn't, the receiver would be expecting to be processing audio from the HDMI input & would ignore the digital co-ax. You may also need to select that output on the monitor in order to active it, which, in most cases, would be odd. I was attempting to access the owners' manuals for these units & decided to respond with basic info hoping to get you up & running. Respond to this post if you have any additional questions.
peace-out
Posted on Feb 04, 2009
Anonymous
  • 60 Answers
SOURCE: LG 5010 42" + Xbox360 + DVD RECIEVER/ Surround Sound SET UP HELP!
soulshaun:
I need some clarification before we can proceed. Which audio/video cable did you use to connect the 360 & your home theater receiver & TV/monitor? It makes a difference which you use. The HDMI cable would be the preferred one to use. The fact that the receiver only has 1 HDMI connection limits your options for other digital connections. Respond to this post & I can provide additional info. I have found that when responding to someone's question, I have a tendency to provide too much info on the 1st response.
peace-out
Anonymous
SOURCE: LG LCD TV no sound
LG tv flatron no sound, picture everything else is fine but no sound what can be done to fix it
Posted on Feb 21, 2009
My sanyo dp46841 stopped receiving analog signal. Any suggestions?
I guess there are no longer analog signals worldwide. Try to connect cable tv to video input of tv.
Nov 18, 2016 | Sanyo DP46841 46 LCD TV 1920x1080, 60 Hz,...
Sanyo LCD TV no picture or sound with directTV
If the Direct TV box is working with other TVs, the problem is in the connection to the TV. In many TVs the automatic sensor works to detect what is being plugged in. In some, it has to be selected through the menu.
Jul 10, 2012 | Sanyo 42 in. LCD TV
My new 55in sanyo lcd tv has sound but no picture. The tv is one week old. Is the problem the backlight or something else?
Tv only a week old take it back were u bought it,trade it in for another tv.Tv have a picture than flashes only a few sec. than died have sound left only?Yes,than those tv 2 long LCD inverter boards are dead.These tv 2 long LCD inverter boards are only to help the tv to have a backlight for tv LCD screen panel only to produced pictures.
Jul 14, 2011 | Sanyo DP46849 46 in. HDTV
Sanyo DP46848 has sound but no picture.
Tv turn now,have a flashes of picture a few sec.than dies have sound left only?Yes,than ur tv have a 2 long boards are dead that call LCD inverter boards.These 2 long LCD inverter boards help the LCD screen to have a backlight to produced a picture.Tries websites like Shopjimmy.com,Ebay.com to buy those 2 long refurbishes LCD inverter boards for the replacement.
Dec 07, 2010 | Sanyo DP46848 LCD TV
My 42" sanyo lcd has
Hello, a no picture with sound condition can be caused by several things inside your LCD TV. A power supply circuit with a missing voltage source could be one cause of the problem, an inverter circuit or HV circuit could be another. The best answer to your question is to have it checked out by a qualified tech. If you have a little knowledge of electronics you could try to repair it yourself, you can sign up for our great tech support where they can assist you on the steps to take to get it up and running.
Nov 06, 2010 | Sanyo 42 in. LCD TV
I have a 46' lcd sanyo... we have sound but no picture...and the off and on button keeps flashing...hadnt had any problems until now...how can i fix this..we havent had the tv 7 mths yet??
The tv less than a year old?Call the hot line in the owner manual for warrenty repair.The tv Tuner board have pronlems,that the board,where the coalaxial broscasting signal cable plug into it.
Jul 16, 2010 | Sanyo DP46849 46 in. HDTV
I have no picture or sound, power light will come
I would get it fixed under warranty ASAP! not a good sign. If you open it, it will void warranty.
Please see my basic troubleshooting guide:
http://s807.photobucket.com/home/budm/allalbums
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: try www.shopjimmy.com or Ebay
Jun 22, 2010 | Sanyo DP46848 LCD TV
Blue picture
It is your "vergin media box" outputting a blue screen!
When this TV has no input it displays a msg box "No Input Signal" or "Signal out of Range" (PC video resolution is not correct.)
Jun 26, 2009 | Hyundai Electronics E465D 46 in. LCD TV
Trying to hook my sanyo 32in up as a monitor for my computer running on windows xp when I hook it up it gets sound and acknowledges the cord is connected(the no signal sign goes away) but the screen just...
Your computer may be sending out a video signal that's too high of a resolution for your TV to display. Try reducing the resolution of the computer video signal.
May 13, 2009 | Sanyo DP32648 32 in. LCD TV
HDMI XBOX360 Elite -"No Signal"
The connection order can be a key issue as to whether or not the HDMI signals will pass through the system. For best results the receiver should be turned on first, then the source device(s) and then the display. The reason for this has to do with getting the equipment to handshake properly for the HDCP protocol.
If HDMI video will not pass through your receiver, you may with to just connect the xbox using the component cables. Since component will pass through 720p and your TV is 1080i you should expect the same qualtiy and a more crisp picture.
Oct 12, 2008 | Denon AVR-2307Ci Receiver
LG 42PX5D 42 in. Plasma HDTV Logo
67 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
